Not able recieve CAN frames using stm32_can.cpp
Posted: Thu Nov 21, 2024 3:46 pm
Hi, I am currently can send CAN frames using stm32.send() function but cannot read CAN frames using the function I created inside stm32_can.cpp
I tried to setup filters to allow every can frames to pass in but can_fifo_pending() always returns 0. Any hints of how I can receive CAN frames? Thanks in advance for the help
int32_t Stm32Can::CANReadFrame(uint32_t *pCanId, uint8_t *recvData)
uint32_t id = 0;
bool ext = true, rtr = false;
uint8_t length = 0, fmi = 0;
uint32_t data[2] = {0}; // Buffer to store received data (8 bytes)
uint32_t pending0 = can_fifo_pending(canDev, 0);
uint32_t pending1 = can_fifo_pending(canDev, 1);
addToTrace(MOD_HWIF, "fifo pending0: ", (int16_t)pending0);
addToTrace(MOD_HWIF, "fifo pending1: ", [(int16_t)pending1);]
// Ensure that the CAN device (canDev) is initialized and properly configured
if (canDev == NULL) {
printf("CAN device is not initialized.\n");
return -1;
// Attempt to receive data from FIFO 0
int pendingMessages = can_receive(canDev, 0, true, &id, &ext, &rtr, &fmi, &length, (uint8_t*)data, 0);
// addToTrace(MOD_HWIF, "CAN ID: ", (int32_t)data);
if (pendingMessages > 0) {
// printf("Received data from FIFO 0. CAN_ID: %lu\r\n", id);
addToTrace(MOD_HWIF, "CAN ID: ", (int16_t)id);
// Set CAN ID to the pointer provided
*pCanId = id;
// Copy the received data into recvData, ensuring no overflow (recvData should have 8 bytes)
memcpy(recvData, data, length); // Use 'length' to copy only the required bytes
// Print additional information for debugging
// printf("Data Length: %u\r\n", length);
// printf("Extended ID: %s\r\n", ext ? "Yes" : "No");
// printf("RTR: %s\r\n", rtr ? "Yes" : "No");
lastRxTimestamp = rtc_get_counter_val();
return 0; // Success
} else {
// If no messages were pending, print a debug message
//addToTrace(MOD_HWIF, "No CAN");
return -1; // Indicate failure to read data
