Outlander
Posted: Mon Mar 02, 2020 9:11 pm
Hi
All i just got my hands on a v3.0 board and straight into taking apart my outlander inverter.
So far im contemplating to use the existing outlander inverter board to supply all the voltages needed to the gates driver board etc.
I have powered up the inverter board with the gate driver board disconnected and i get a 10khz signal at 8v on the resolver exciter.
5v to the current sensors and 2.5v out of both current sensors
The current sensors are neatly packed and i hope to keep them, i did trace the signal from each one to the original IC and it still stays at 2.5v
Im hoping there is an easy solution for current sensor and voltage sensor thats somewhat oem looking at least.
Looking at the Leaf daughterboard at a guess the current sensors are 3.3v items not 5v items or does the board use a simple voltage divider to get the correct signal voltage
The power/canbus and resolver wires will be easy to complete, however the motor has two temperature sensors and the v3.0 board only has one input. So that will need looking at.
Also the original cabling on the outlander rear motor is not terribly big 38 is written on the battery terminal and 22 on the phase terminal.
Most of the bus bars used are 15mmx1.5mm except for slightly thicker ones straight from the igbt's
I hope to check the sin/cos peak to peak voltage tomorrow when i get time from the resolver.
I also have a 100v dc pack on standby for testing from my ebike when im ready for light testing.
