Page 1 of 1
[Help] Model 3 PCS board wont work
Posted: Fri Dec 27, 2024 11:17 am
by CAWRESTLER95
I recently got the Tesla model 3 PCS and the board sold by Damien. I wired everything up and got to testing I was able to connect to the wifi network but then once navigating to 192.168.4.1 I see no parameters and I also see SWD error whenever I try to upload files. I am assuming the esp board isnt communicating with the STM32 board ?? but not too sure. Anyone have any ideas on what could be wrong or thoughts on where I should start to fix this. Any help would be greatly appreciated thank you
Re: [Help] Model 3 PCS board wont work
Posted: Fri Dec 27, 2024 12:58 pm
by Jack Bauer
Why are you trying to upload files? Board is supplied programmed. Also swd upload is non functional.
Posted: Fri Dec 27, 2024 6:25 pm
by CAWRESTLER95
Yea I was wondering if for some reason it hadn’t been shipped already programmed. I actually ended up using an st-link to program the board but that didn’t help either as the board indeed comes programmed. Just trying things because I’m not sure where my issue is
Posted: Fri Dec 27, 2024 6:38 pm
by tom91
CAWRESTLER95 wrote: Fri Dec 27, 2024 6:25 pm I actually ended up using an st-link to program the board
If the running LED does not blink the STM32 has not entered run mode. You might have messed up the programming by trying to reprogram it.
Posted: Fri Dec 27, 2024 7:44 pm
by CAWRESTLER95
It behaved the same prior to trying to program it. What should my next step be 🤔
Posted: Fri Dec 27, 2024 7:54 pm
by tom91
What did you assemble.
When powering it on only providing it ground and 12V Permanent does the Power Led light?
If the Power Led Lights but the ACTTY Led does not light the STM32 is not going into the main programme for a some reason.
I note you wired all the wires just willy nilly without using a connector. This looks very sketchy and is a very easy way to create issues and damage things.
Posted: Fri Dec 27, 2024 10:55 pm
by CAWRESTLER95
Yes when supplying just 12v and ground the power light stays on but actty led does not light. Any ideas on what I could try or test to further figure out the issue? I’m just stuck here
Posted: Sun Dec 29, 2024 7:25 pm
by Bratitude
CAWRESTLER95 wrote: Fri Dec 27, 2024 10:55 pm Yes when supplying just 12v and ground the power light stays on but actty led does not light. Any ideas on what I could try or test to further figure out the issue? I’m just stuck here
get a proper header wired up first
Posted: Mon Dec 30, 2024 12:14 am
by Steve16
Just to confirm, did you disconnect from the PCS for this test? Also, you might try removing the wifi board and PCS and booting with 12V (only 2 wires connected to the board), I believe you would see the activity LED blink if the STM32 is booting correctly. This would isolate the board from any potential external stimulus.
Posted: Mon Dec 30, 2024 8:40 pm
by CAWRESTLER95
Steve16 wrote: Mon Dec 30, 2024 12:14 am Just to confirm, did you disconnect from the PCS for this test? Also, you might try removing the wifi board and PCS and booting with 12V (only 2 wires connected to the board), I believe you would see the activity LED blink if the STM32 is booting correctly. This would isolate the board from any potential external stimulus.
Will try this and report back
