ZombieVerter T15Stat stuck off
Posted: Sun Feb 02, 2025 2:41 pm
Hello,
I have searched the forum but haven't been able to get a clear answer on this. I am currently building up my Zombieverter connectivity. So far I have -
1. Zombie powers on (12V and ground permanent are connected)
2. Zombie is reading IVT Shunt voltages - so that little system is sorted. My test HV is ~45V.
3. Zombie is reading throttle values on both throttles fine.
4. Contactor ground are all connected to their respective Zombieverter pins.
5. Contactor positive is connected to common 12v+.
I now want to turn on ignition and start in order to close my contactors. No matter how I try, I cannot get T15Stat to go from Off to On.
So, my question - is there any trick here?
Or is it as simple as apply persistent 12V+ to the 'Ignition T15 In' pin (pin 15 on the diagram)?
The only hiccup I have had so far is that I initially thought that the contactors were connected 'high', so I connected the contactors to a common ground, and connected my 12V bench power. All the contactors clattered closed instantly, and I turned it off. If anyone knows if this would have caused any damage please let me know.
Here are my parameters, in case that's relevant. Most oft hem might be nonsense, as I said, I am sort of iteratively connecting things.
