LDU direct to VCU ?
Posted: Mon Feb 03, 2025 5:28 pm
by medo
Is there anything against supplying the LDU with 12V permanently and connecting the negative line directly to VCU inverter ls power switch pin 32, without a relais ??
Re: LDU direct to VCU ?
Posted: Mon Feb 03, 2025 6:39 pm
by Bratitude
yes, its not designed for that. dont do that
Posted: Mon Feb 03, 2025 7:02 pm
by medo
Do you think that more than 2 amps flow through it during operation? It is not designed for that, but on the table it works like this
Posted: Mon Feb 03, 2025 8:25 pm
I guess the answer is it was never intended to be used at that amperage but if it works for you, you can do it at your own risk.
The LDU inverter probably consumes 1-1.5A when spinning a motor. Have you tested that? Does the low side driver on Zombie become warm?
Posted: Mon Feb 03, 2025 8:47 pm
by medo
outside the engine it gets 35 C° warm at room temperature using a thermal imaging camera, I haven't tested it in driving mode yet, but I will test it and report back, it would make things less complicated and fewer components would have to be installed
Posted: Mon Feb 03, 2025 10:18 pm
by muehlpower
The LDU board is groundet to the case. Do you ground the LDU at your bench test?
Posted: Mon Feb 10, 2025 11:11 am
by medo
you are right, the board is grounded, so it doesn't work like that and a relay must be used
