Outlander Rear <-> Zombie wiring requirements
Posted: Mon Feb 10, 2025 12:59 pm
Hello,
I have been making use of the wiki and forum posts to wire up my Outlander Rear inverter to the zombieverter. I have made good progress with precharge and the throttle, but I am unable to get my InvUDC to go above 0V, or to get my InvStat to go On.
I would like to confirm that I have met the minimum requirements to make get InvStat = On and InvUDC ~ udc3. If I have met the minimum requirements, then my assumption is that my Inverter connector is broken and I need to make a new one. I have two inverters and neither work which is why I want a sense check.
Here is the detail of my current setup. I have also attached params.json and cmd.json.
The inverter is connected to my Zombie and to 12v+ and ground. The inverter is NOT connected to the motor, via either the 3 phase HV lines or the signal cable.
Zombie stats:
- Using Version 2.17a
- Ignition, start and precharge are working.
- Opmode is run.
- Throttle is calibrated.
- I am using CAN1 for all CAN. Currently IVT shunt and inverter are the only things connected to it, and IVT Shunt is working fine - so the can network is working. Shunt and Zombie are the two terminal resistors.
I think I have wired the inverter relay correctly. At any rate, when the ignition is off, no 12v is flowing to the inverter. When the ignition turns on, 12v is flowing to the inverter. I have checked all lines for continuity from their origin to the inverter socket.
Here are ALL the wires that are connected to the inverter:
1. HV + and - from contactor box to inverter
2. 12v relay feed to 12v in on inverter side
3. Ground directly from my 12v battery to the ground wire on the inverter side
4. Ground directly from my 12v battery to the remcu shut down signal line
5. Ground from battery to the case of the inverter for good measure
6. CAN H to CAN H
7. CAN L to CAN L
So, finally, my question. Is there anything I might have missed in my setup thus far? As far as I can tell, as long as I can get into run mode, I'm supplying 12v to the inverter, and the can lines are connected I should be getting comms.
Zombie stats:
- Opmode is run.
6. CAN H to CAN H
7. CAN L to CAN L
