V 2.20a stuck in charge mode
Posted: Sat Feb 15, 2025 9:32 pm
Hello
Summary questions.
1. Is pre-charge really fast, like 1sec?
2. Should the pre-charge relay stay on after pre-charge is complete?
3. Why am I stuck in opMode Charge?
I am working on getting a new install of the zombiverter working. I have upgrated to version 2.20a.
My system is a gen2 leaf(full stack), 40kwh battery, isa current shunt.
When I power up the system up I have no errors and it is in Charging mode. It makes me a bit nervous as it quickly engages all the HV relays. I think the pre-charge is working ok. If I disconnect my resistor it then pre-charge fails. It looks like the pre-charge contactor remains on after the pre-charge is complete, hopefully that is normal.
My next step is to turn on the ignition via power to pin 15(ignition). Nothing changes on the web interface.
Next I apply 12V to pin 52(the start) button. again no change in the web interface.
I have looked at spot values and see my voltage udc is at 390 and INVudc 390
At least some part of the can bus to the controller must be working as the inverter temp is 12 C.
My throttle seems to work as I see pot and pot2 change, dir shows drive.
At this point I am a bit stuck and opted to post here and then go dig into the code.
Does any one have any suggestions?
Aaron
Summary questions.
Aaron
