Zombie UDCSW negative value
Posted: Fri Feb 21, 2025 12:27 pm
Hey all,
Currently combining all my parts to test a first motor spin. Previously I tested communication between the Zombie and my Outlander motor, inverter and charger, this all went well for as far as i could test them. After that I calibrated a throttle pedal which i picked up. When testing the motor, inverter and charger I also tested the BMW S-BOX to see if the contactors worked like they should, by setting UDCSW to 0 volt the contactors happily clicked away at the moment they needed to.
Recently I did a Zombie update to 2.20. Now I'm at the point where I want test the motor, but before that, I wanted to make sure that all component were connected and functioning well, so I fired up de Zombie webpage and saw that UDCSW had a value of -20 (negative). I have tired to change this value many times but it keeps reverting back to -20 after I hit refresh. Other parameters gave no problem changing them. I Have tried to change the UDCSW value with and without my components connected. I tried flashing the 2.20 software again this didn't result in what I hoped for.
Even when the UDCSW value is at -20 the Zombie goes into RUN mode when pushing the start button, but at that point I hear no clicking of the contactors (double checked the wiring).
Any one has an idea how to be able to change the value?
Many thanks!
Sander
Many thanks!
Sander
