inverter stays in run mode, even if errors are present
Posted: Wed Mar 12, 2025 8:56 pm
by medo
Is it normal that the ldu inverter stays in run mode, even if errors are present
Re: inverter stays in run mode, even if errors are present
Posted: Thu Mar 13, 2025 6:02 am
I suppose the inverter was restarted after it tripped? Lasterr isn't reset then
Posted: Thu Mar 13, 2025 8:29 am
by medo
The LDU is started via the VCU, this happens with every start, in the VCU at the spot values it is shown that it is off, but in the LDU it is still set to Run, at least here on the desk
