Is Such a Battery Possible?
Posted: Wed Apr 02, 2025 6:40 pm
Hey all!
I'm looking for a suitable battery for my SDU, but I'm having trouble finding one that fits my unique requirements. I'm posting here as a last resort, as I'm all out of ideas. My needs are as follows:
~350-400V nominal
~250 kW peak discharge (10 seconds)
<300 lbs (no more than 20 kWh needed, in general the lighter the better)
It seems to me that this is simply impossible. I've looked far and wide and thought deeply, but I simply can't find a solution, here are some of my attempts:
1: Find an OEM battery
-No manufacturer (I can find) makes a suitable EV battery
-No manufacturer (I can find) makes a suitable battery for home storage or seemingly any other industry
2: Use a small number of OEM EV modules, then a DC-DC converter to get the required voltage
-DC/DC converter would need to be capable of ~96V to 400V and 250 kW peak
-No manufacturer makes such a product, and my custom fabrication inquiries have been rejected
-It seems to me like this is a market to be filled; if one could produce such purpose-built and efficient converters for power-heavy, light EV builds, it seems to me that this could become a viable method of EV conversion power
3: Manufacture a battery from OEM Cells/Pouches
-Running the numbers, no matter how I wire it, they always lack. It's either an insufficient discharge rate, insufficient voltage, or ridiculously excessive weight
4: Use an above solution (likely the manufacture custom battery) to hit all goals EXCEPT peak discharge rate, and then use bank of supercapacitors to be able to make up the total of 250 kW for 10 seconds that then recharge from the battery afterward
-The magnitude of size and weight of supercapacitors is absurd (and price too)
-Convoluted and difficult system
So, I'm out of ideas. If anyone has any, I'd be happy to hear em! And if it works out, I might just give some monetary thanks. And yes, I have tried my hand at finding anyone with a similar issue.
~350-400V nominal
