How to access to Zombieverter via Wifi?
Posted: Sun Apr 06, 2025 3:56 pm
by Bintang 5
Hi there,
I have a Zombieverter that I purchased quite some time (years?) ago. It sat on the shelf, but now I want to use it. I wired it up, the ACCTY LED is flashing, but I do not understand how to get access via Wifi.
There is a thread about problems with the ESP8266 Wifi module but do not understand it.
Can someone help me out with a step-by step description what to do?
thank you
EDIT: problem solved. After re-booting the Zombieverter I found the Wifi access point under the name "ESP-1C5579" and have access to the interface now. Yet the name of my access point does not match with the ones mentioned in the ZombieVerter VCU wiki-page ("inverter" or "zom_vcu").
Should this be updated?
Re: How to access to Zombieverter via Wifi?
Posted: Mon Apr 07, 2025 1:27 pm
by Bratitude
Bintang 5 wrote: Sun Apr 06, 2025 3:56 pm Hi there,
thank you
That’s the stock ssid of the wifi boards, so add it to the list of possible names
