VCU as a BMS main on the CAN bus
Posted: Thu Apr 10, 2025 11:27 am
Hello everyone,
in the Johannes VW touran update he started using MEB battery platform modules in his conversion and from what I gathered from the video and on the wiki, he is directly using the VCU as the master BMS to use with the BMS slaves that come with each module.
Now my situation is similar as in my conversion I will be using MEB modules (got the whole ID4 battery pack 82kw for dirt cheap).
Now before buying a bunch of parts, i have questions:
1. The obvious question is what are the downsides to this route of implementation? From what I gather there might be that ID can clash if there are more devices on the network, but Johannes has a bunch of stuff and it seems to work fine for him.
2. If I go this route the idea would be to try to implement this into Zombie, unless I missed something and there is this option already and that probably answers all my questions. It has SimpBMS support, but from what i understands it for "high level" CAN commands not BMS slave management.
3. Plan B which is probably plan A, get the same-ish setup as Johannes is using and start hacking away for stuff i need.
Any suggestions, solutions, ideas or already WIP things that can help are very welcome.
