Hybrid Conversion optimization newb questions
Posted: Wed Apr 30, 2025 2:30 pm
Hello, I am completely new to EV conversions. I found this open source project and think it would be a fantastic choice for me. I appreciate everyone who has worked on this because it's by far the most cost effective solution for me. I have a 90' integra I want to convert to be hybrid. I am planning on mounting a telsa SDU in the rear with 6 chevy volt battery modules. It should be around 270v and 10kwh. I have a few questions on integrating the two systems together. The car will be used for street strip, the ICE engine is a b18 with a turbo that makes around 350-400hp.
1) When using the electric motor in conjunction with the gas engine I need to use the clutch switch to enable the electric motor so I can use launch control on the gas engine which required clutch in and full throttle. Should I wire the clutch switch to to forward position, or the start input?
2) I wanted to mainly use the EV as a launch assist and disable it after a certain gear, my ecu has canbus and I can program an output based on gear but wasn't sure how to have the inverter interpret this and disable power. I know disconnecting the motor at high current can cause inverter failure. Which then leads to my next question
3) Can the motor free wheel without causing a regen effect If I want to run only the gas engine and have the rear wheels still be spinning up to 130+mph, If this is not the case, would leaving the precharge contactor/relay/circuit enabled be safe when going those speed. or should I be inputting a 0% throttle and leaving the inverter enabled to provide zero regen and zero boost.
4) Sorry for so many questions, I am concerned about having regen coming on when braking hard from high speeds, I am hoping to use the brake switch input to disable regen but I'm curious if i can taper out regen at a certain rate and tune it. Also with the brake switch input does this connect to the brake light input or brake signal, and does the switch need to feed 12v to the input or ground?
Any help here would be greatly appreciated, I will also continue digging into as much information on the forum and wiki as possible to educate myself further
