Would keeping the Overdrive help range?
Posted: Mon Jun 16, 2025 12:57 pm
HI All,
I haven't posted much about my project because it is still in bits and pieces all across southwestern Germany but on the weekend I took my differential to a specialist to have it refurbished and put into an aluminum case (to save weight).
The car is a '72 Triumph Spitfire. Because of the low initial weight of the car (around 740 kg) and the overall size getting more than 20-25 KWh worth of batteries into is going to be challenge (I guy has already done it and lives only 10 km from me so I know it can be done!).
As such I am trying all I can to save weight (aluminum parts where allowed, lighter wight sound deadening etx) and power (LED where legal and redoing the wiring loom) use no matter how minuscule.
The specialist also does transmissions/gearboxes and has an overdrive for the Spitfire and suggested it might help.
On the dino-juice engine the overdrive is able to drop the RPMs be around 500 in 3rd and 4th gear (the car will be keeping its transmission gearbox for various reasons).
I am not sure the added weight (about 4-5 kilos) and the added complexity would really translate into higher overall range.
Does anyone have any thoughts on this?
Thank you in advance!
