Zombieverter with Ampera water heater
Posted: Tue Aug 12, 2025 11:00 am
I need some help getting my heater to work. As the title says, I'm using the Zombieverter and an Ampera water heater.
What I've done so far:
- Connected the HV cables to the spare connection of the Mitsubishi rear inverter. So high voltage is applied when the contactors are closed.
- Connected GND and +12V to the "Enable" pin of the 3 pin LV connector
- Selected Heater Type to "Ampera" in Zombie Parameters
- Selected Control to "Enable" in the same section
- HeatPwr to 3200 W, but in the documentation it says that this is not used.
- HeatPrcnt to 50
- Connected +12V to the Hvrequest pin of Zombie via a switch and selected HeatReq parameter for this pin. When I turn the switch on, Heatreq turns on in the spot values, as intended.
The heater is SW CAN controlled. It's the middle pin of the LV connector. Where do I connect this cable? I suppose this is the only missing bit of my set-up (I hope so). Damien got it running in one of his cars and explained the settings for Zombie, but I found no information about how to connect the SW CAN.
Thanks,
Stefan
- HeatPrcnt to 50
Thanks,
Stefan
