Balancing strategies for mixed-capacity cells in DIY EV packs?
Posted: Mon Sep 22, 2025 12:58 am
Hi everyone,
I’m currently experimenting with a DIY EV battery pack that, due to supply limitations, ended up with a mix of cells that have slightly different usable capacities (same chemistry, but not from the same batch).
I know that in an ideal setup, all cells should be matched as closely as possible, but in the real world, sometimes you have to work with what’s available. My concern is how best to handle balancing in this scenario.
- Would a traditional passive balancing BMS be enough, or would it constantly waste energy and heat trying to keep the cells aligned?
- Is an active balancing solution more practical here, or is it just overcomplicating things for small differences in capacity?
- At what point does the imbalance become serious enough that the pack's lifespan is significantly reduced?
Has anyone here tried running a pack with this kind of “imperfect” matching, and what were your long-term results?
Thanks in advance for any insights!
