Modify and compile a program
Posted: Sat Oct 25, 2025 9:59 am
by muehlpower
Maybe I'm the only one here who doesn't get it, but how do I modify a program and compile it? I installed the toolchain and downloaded the latest zip file from git. Now I have a new folder in Programs (x86) and a zip file with lots of subfolders. How do I modify the program and how do I get a bin or hex file that I can then transfer?
Re: Modify and compile a program
Posted: Sat Oct 25, 2025 10:29 am
by manny
You can modify the code with you favorite text editor.
The files are in the src folder
On windows I use WSL linux command line for windows to compile the firmware. With the Make command.
Posted: Sat Oct 25, 2025 11:10 am
by muehlpower
manny wrote: ↑Sat Oct 25, 2025 10:29 am
favorite test editor
Which editor is suitable? Normally, I start the Arduino IDE, type in the program, and then press upload. I can view the relevant program section with the Windows editor and also change it, but without checking the syntax.
What is “WSL Linux command line for Windows”? I can type “cmd” in the bottom left corner of my Windows screen, and then something that looks like DOS appears.
Posted: Sat Oct 25, 2025 11:24 am
muehlpower wrote: ↑Sat Oct 25, 2025 9:59 am
Uhmm thanks for the clarity on what you are on about. Please be more specific.
You can search the forum for threads on compling.
search.php?st=0&sk=t&sd=d&sr=posts&keywords=compile
viewtopic.php?p=76553&hilit=compile#p76553
Posted: Sat Oct 25, 2025 12:36 pm
by muehlpower
Johu recommends in another thread: “Install the latest version of stm32-sine, which you can find on Git, i.e., compile it yourself. It fixes various CAN issues compared to 5.35.R.” 5.35.R is the latest version I can download as a binary file.
On Git, it says to install “arm-none-eabi toolchain.” I did that. I also downloaded “stm32-sine-master.zip.”
The question now is how do I use the toolchain to create the “stm32_sine.bin” file from the “stm32-sine-master.zip” and what can I use to make additional changes to the source code?
Posted: Sat Oct 25, 2025 12:58 pm
Depends on your preference.
I use Docker and this
https://github.com/crasbe/ZombieBuild can be adapted to work for any OI software repo.
For writing code I use Code Blocks.
Posted: Sat Oct 25, 2025 1:35 pm
by muehlpower
I have now installed Code Blocks. It looks good. It found a GNU when it started, which I think is good. Then I opened stm32_sine.cpp and clicked on “build.” I got this error message: "C:\compile test\stm32-sine-5.35.R\src\stm32_sine. cpp|22|fatal error: libopencm3/stm32/usart.h: No such file or directory|||=== Build failed: 1 error(s), 0 warning(s) (0 minute(s), 0 second(s)) ===|"
Johu writes on Git: “The only external dependency is libopencm3, which I forked.”
What does that mean and how should I proceed?
Posted: Sat Oct 25, 2025 1:42 pm
by manny
muehlpower wrote: ↑Sat Oct 25, 2025 12:36 pm
If you want the latest software. You can download it from github. You need to be logged in to github. got to
https://github.com/jsphuebner/stm32-sine/actions
And select the the latest commit of the branche you want. Scroll down to Artifacts and select the FOC or SINE file.
muehlpower wrote: ↑Sat Oct 25, 2025 11:10 am
Visual Studio Code is a good option
WSL is similar to cmd but its linux on windows.
Posted: Sat Oct 25, 2025 2:14 pm
muehlpower wrote: ↑Sat Oct 25, 2025 1:35 pm
On windows I would strongly recommend using ZombieBuild and docker to compile. Code Blocks is not used to compile.
Posted: Sat Oct 25, 2025 2:35 pm
by muehlpower
manny wrote: ↑Sat Oct 25, 2025 1:42 pm
Now I see that. Where is the bin file?
Posted: Sat Oct 25, 2025 2:59 pm
by manny
Sorry did not see that they are expired. Maybe johu can redo the copile or change the expire settings?
Posted: Sat Oct 25, 2025 7:36 pm
by muehlpower
I think I now have Debian Linux, WSL2, Code Blocks, the arm-none-eabi toolchain, Docker and Windows Terminal installed. And I have downloaded the ZombieBuild-main.zip, stm32-sine-master.zip and libopencm3-5ba1bb5f8b0287a0ccec9def20f3a6185c3a2a8e files.
How do I turn all of this into a bin or hex file that I can then load onto my LDU board using ST-Link?
Posted: Sun Oct 26, 2025 9:45 am
by manny
In the command line go to the Stm32-sine directory and execute the commands on the guthub.
https://github.com/jsphuebner/stm32-sin ... #compiling
Good luck
Posted: Mon Oct 27, 2025 9:04 pm
by uhi22
Another way, which was straight forward (for me):
- I forked the repository to my github account.
https://github.com/uhi22/stm32-sine
- Have git installed on my windows 10 machine.
- Open a git bash
- clone the repository to my machine: git clone
- change into the new directory: cd stm32-sine
- using a text editor (I prefer Notepad++), change in the file param_prj.h the VERSION number
- back in the git bash, check the differences (git status) (git diff), stage them (git add .), commit them (git commit -m "changed version") and finally push them to the github server (git push)
- On github, the continuous integration is enabled, which means, that github itself will build every change directly, and provide the binary files (bin and hex) in the "actions" tab:
https://github.com/uhi22/stm32-sine/actions
Pro:
- No need to install the tool chain for building.
- The changes and the binaries are accessable by everybody for "community testing"
Contra:
- Needs a github account
- Pushing un-tested software to github is a bad habbit. So only recommended for very small changes.
Alternatively made a local build. On windows 10. Precondition: git installed.
- Open a git bash
- using a text editor (I prefer Notepad++), change in the file param_prj.h the VERSION number or whatever else
- back in the bit bash, follow the compile commands described here:
https://github.com/jsphuebner/stm32-sine#compiling with the difference, that on my windows the "make" does not work, instead I have to use mingw32-make.
- mingw32-make get-deps
-> this takes two minutes to compile a lot of library stuff
- mingw32-make
-> compiles and links the project:
OBJCOPY stm32_sine.bin
OBJCOPY stm32_sine.hex
text data bss dec hex filename
50988 4596 928 56512 dcc0 stm32_sine
Posted: Mon Oct 27, 2025 9:31 pm
by uhi22
muehlpower wrote: ↑Sat Oct 25, 2025 7:36 pm
- 1. Find out how to open a command line ("shell").
- 2. In the shell navigate into your stm32-sine directory (that you have extracted from zip, or got using the git clone command). Something like cd ~/downloads/stm32-sine
- 3. make get-deps
- 4. make
I'm not sure whether it works to put the stm32-sine-master.zip and the libopencm3...zip together somehow. I prefer getting the data from github not using the zip, but using the command "git clone".
Posted: Tue Oct 28, 2025 3:12 am
I think it may not work with downloaded zip as the git submodule command will likely fail.
So use clone instead
Posted: Tue Oct 28, 2025 1:04 pm
by davefiddes
Yep. The GitHub releases source tarballs don't build because they are missing the submodules. I have added code to create working standalone source tarballs for the stm32-sine M3_DU project:
https://github.com/davefiddes/stm32-sin ... 55C2-L73C1
If you just want binaries of a up to date stm32-sine then the release I put together here:
https://github.com/davefiddes/stm32-sin ... DU_v5.39.0 might be of interest. It has the most recent CAN fixes and has been tested on the M3_DU. No testing on other boards but it *should* be OK.
Posted: Tue Oct 28, 2025 1:09 pm
by muehlpower
Ubuntu is installed, make and git are running. “make get-deps” produces an error message.
Posted: Tue Oct 28, 2025 1:54 pm
by davefiddes
make get-deps will not work on the unzipped source. You need to "git clone
https://github.com/jsphuebner/stm32-sine.git"
Posted: Tue Oct 28, 2025 3:23 pm
by muehlpower
I have now created a local copy using git clone, and the result looks exactly like the unzipped version of the downloaded master zip file. Is there a difference?
Posted: Tue Oct 28, 2025 4:38 pm
by davefiddes
The "git clone" will have created a special ".git" folder which is not present in the zip file. You should be able to run "make get-deps" now which will fetch and build libopencm3 and libopeninv which the project needs.
Posted: Tue Oct 28, 2025 6:35 pm
by muehlpower
davefiddes wrote: ↑Tue Oct 28, 2025 4:38 pm
You're absolutely right, I didn't see that. “make get-deps” worked, and so did “make.” So the newly created hex and bin files should be the ones I can load onto my board? I've only changed the version number for now and will test whether it's correct after loading.
What does the warning mean?
Posted: Tue Oct 28, 2025 7:16 pm
by davefiddes
Yep. You can take the bin file and upload it via the web interface or CAN as you would with an official release. The stm32_sin file (without an extension) is what you need for debugging.
The warning can be safely ignored. It's a compiler bug(ish) cause by some slightly convoluted code in libopeninv. Newer compilers like gcc 15.1 don't complain.
