Page 1 of 1
Lexus ls460 TCU aa80e
Posted: Sat Nov 15, 2025 12:31 pm
by Neomaximus55
Hi everyone. I stumbled upon this forum by pure chance. Where I'm from, electric traction and information about new cars aren't as widespread.
Given the sanctions, I don't know how people will receive me here; I'm from Russia, Siberia.
I'm interested in either manufacturing an AA80E/AA80F automatic transmission control unit.
Or controlling the stock control unit via the CAN bus from this car.
The main problem is that I need to swap the 1UR-FSE engine to a different chassis. The engine is already running on a third-party ECU without the CAN bus.
I don't want to install a manual transmission.
Re: Lexus ls460 TCU aa80e
Posted: Sat Nov 15, 2025 1:38 pm
by midway
The people here are reasonable and non-political. I doubt they'll be able to help you with your question. The forum is quite narrowly focused. I think you can find help here:
http://orioncars.ru/
Posted: Sat Nov 15, 2025 1:55 pm
by Neomaximus55
midway wrote: ↑Sat Nov 15, 2025 1:38 pm
Sorry, you're a bit inattentive.
My 1ur-fse works at analogue VEMS ecu.
Orion Cars only works with factory ECUs.
This guy won't share his knowledge. He's making money.
Posted: Sat Nov 15, 2025 2:09 pm
by midway
This forum only deals with starting electric motors or hybrid transmissions separately from the internal combustion engine. It does not cover automatic transmission control units. If you're installing a Tesla engine in a UAZ, they'll help here.
Posted: Sat Nov 15, 2025 2:11 pm
by midway
Neomaximus55 wrote: ↑Sat Nov 15, 2025 1:55 pm
Everything has its price
Posted: Sat Nov 15, 2025 4:06 pm
by Neomaximus55
midway wrote: ↑Sat Nov 15, 2025 2:09 pm
https://github.com/damienmaguire/8HP-TCU/tree/main
Dear friend)) I came to this forum from here. The project's author is also on this forum.
And the 8hp** gearbox is very similar to the AA80e.
Sorry if links are prohibited.
Posted: Sun Nov 16, 2025 12:43 am
by jrbe
This is the wrong forum for things like this. Check out:
- the megasquirt transmission controller
- diy efi
- speeduino transmission controller
There are others too.
Posted: Sun Nov 16, 2025 4:49 am
by Neomaximus55
jrbe wrote: ↑Sun Nov 16, 2025 12:43 am
- diy efi
some can, others can't?
https://openinverter.org/forum/viewtopic.php?t=6047
Does anyone have a CAN-BUS analyzer for Lexus/Toyota?
I posted a thread on the OEM forum.
I have a stock automatic transmission unit. Perhaps it needs to be fed RPM, engine load, and ABS speed information, and it will shift gears 1-8.
Knowledge is power.
Posted: Sun Nov 16, 2025 12:27 pm
by jrbe
This is a forum for EVs and stretches to people attempting to do hybrids. The knowledge base here is around EVs. It's a bit like going to a sewing forum to ask about plastic surgery.
Understood you found a controller that might work for you here. We're trying to share that this isn't the best place for you to get support for what you're trying to do. If you decide to try to use that controller you'll likely get only partial support from this forum. It's not this forums focus, it's not about you, it's about what you're trying to do not fitting this forum / knowledge base as well as some other forums.
The person who developed that controller hasn't really had the time to get very into it and it's focused on ev swaps / hacking.
Can bus software,
https://saleae.com/downloads other hardware works with their software.
Posted: Sun Nov 16, 2025 4:08 pm
by Neomaximus55
jrbe wrote: ↑Sun Nov 16, 2025 12:27 pm
Can bus software,
I heard there's a forum for larger e-scooters
If that's what the rules require, and I can't find help here, I'll leave this place.
I was hoping to at least communicate with people who had encountered this, or who would suggest a way.
In russian forums.... One answer,on all qwestions- "go to master,ask specialists")))
