vw hybrid battery max kw output
Posted: Sun Dec 07, 2025 3:24 pm
by ben22
hi, im looking for a battery that can run a 160kw nissan leaf motor/inverter
can anyone tell me if the older 8.7kwh gte cells have higher discharge rate than the newer 13kwh?
i understand that it will be pushing these cells very close to their maximum limit
and the packs internal fuses may need to be changed
any other suitable battery modules that i should be looking at? sub 100kg 96s capable of 400a discharge
cheers Ben
Re: vw hybrid battery max kw output
Posted: Sun Dec 07, 2025 6:15 pm
by ben22
this ukranian website evcell.com.ua states
samsung sdi 28ah cell CM0280R0001D max discharge 280a
https://evcell.com.ua/shop/samsung-28ah-104-wh-li-ion/
samsung sdi 37ah cell CS0370RT001A max discharge 370А
https://evcell.com.ua/shop/samsung-37ah-137-wh-li-ion/
not even sure if these are the correct cells, or if the discharge rates are to be trusted, i thought lower capacity would equate to higher power output, maybe this is an incorrect assumption, and the older battery pack is older tech?
Posted: Sun Dec 07, 2025 6:31 pm
by ben22
this website https://evshop.eu/en/batteries/1074-12s ... odule.html states the older 8.7kwh gte pack has a max discharge of 400a for 10 seconds on the cell level
Posted: Sun Dec 07, 2025 6:52 pm
by ben22
https://www.power-and-storage.de/shop/S ... p266060893
these guys are saying 335a discharge for 10 seconds on the newer 13kw pack (37ah cells)
