How To: 12v Inductive Chaging (retrofit Heated Steering Wheel)
Posted: Thu Dec 11, 2025 11:16 pm
Stupid idea of the day:
- Direct heating is best heating. Heat my cold fingers in the Canadian winters instead of heating the whole car, at 1% the energy cost.
- My car is old. Also, friends with normal vehicles might use this. No heated steering wheel. No vacant wires in clockspring. No more modern version of steering wheel available.
- I want to add (or DIY) basically heated motorcycle grips. It's just a 12v heating pad covered with fabric. Cheap ones are nichrome. Nice ones are some kind of carbon fiber mesh. Or use nichrome wire. Doesn't matter, that's the easy part.
- How do you power it? No clockspring. Would have to support 4 full turns, so a retraction mechanism would be 60" long (5 feet), not reasonable.
- "Heated steering wheel covers" are a fraud. They either have an onboard battery, or you have to disconnect them while driving, defeating the purpose either way.
That leaves me with inductive charging.
So, I figure, a 4-cell LiFe or LiIon (I don't care about wasted capacity), tucked on the underside of the steering wheel. But then how to charge it?
MOST of the time, the steering wheel is pointed forwards. So, recharging when pointed forwards should work.
I don't really understand the specifics and impacts of using various different wireless chargers. That's where I could use help. I can google, but I'm just in Component Soup and picking randomly.
Ideally:
- Up to 15v input.
- 12-15v or whatever output.
- Probably around 1amp, as most grip heaters are ~10 watts. More might be nice.
- Temp control might be nice, or just a 50% power toggle.
There are lots of inductive chargers, but they're VERY sensitive to range. And I will probably be deforming the coil a bit (narrower and more oval, versus circular), but I don't know if that throws it out of resonance or whatever might be needed.
Just random googling:
Random choice 1:
(I guess the forum won't allow me to post links to Amazon? Damnit, how am I supposed to make reference to stuff then?)
(up to?) 24v input, 12v3a output?
Random choice 2:
12v in, 12v out. 1.8a.
Random choice 3:
12v in, 4 LEDs out? (cut and replace).
Random choice 4:
12-30v in, 12v 2.5a (peak) out.
So you get the point, I'm just throwing darts at amazon and have no idea what works for what.
Some of these coils are pretty huge. I want them kind of wide and flat if I could.
I have a feeling someone is going to say something like "Why don't you just use *Link*?" because they know exactly what I should be using instead. At least that's my hope.
Some of these say you CAN'T get them too close or they'll burn out. I don't really have a grasp of inductance. I get transformer basics, but only coils ratio and stuff. Is there a better thing I should be doing or using?
Any help appreciated.
Ideally:
- Up to 15v input.
Random choice 1:
Random choice 2:
Random choice 3:
Random choice 4:
