Leaf BMS used with other cells
2010RELEAF
Post by 2010RELEAF »
Does the leaf bms keep track of battery capacity. If my battery chemistry and pack voltage is the same as factory will it be able to do a 100kWh instead of the 24kWh it came with?
ianlighting
Has thanked: 258 times
Been thanked: 189 times
Re: Leaf BMS used with other cells
Post by ianlighting »
2010RELEAF wrote: Sun Dec 28, 2025 3:22 am Does the leaf bms keep track of battery capacity. If my battery chemistry and pack voltage is the same as factory will it be able to do a 100kWh instead of the 24kWh it came with?
I think you’ll find the BMS is programmed to match the physical capacity. In my build, at one point, I had a 40kWh BMS with 60kWh battery. It meant it displayed 0% battery when it still had 20kWh more available.
