PCB Dimensions for 3D printed enclosure?
Topics relating to the ZombieVerter VCU
loudboy10
Post by loudboy10 »
Are the ZombieInverter PCB dimensions available? I'll be ordering one soon and would like to print my own enclosure. Of course I can take measurements once I have the board in hand, but I'd like to use official specs if possible.
Buying a $50 box with a 56-pin connector when only 16(for Leaf at least) will be used doesn't seem like the best way to go. I'll post the print files here and Thingiverse once created. Thanks!
modellfan
Has thanked: 20 times
Been thanked: 61 times
Re: PCB Dimensions for 3D printed enclosure?
Post by modellfan »
Just buy it on aliexpress. Search for 56pin ecu
Been thanked: 413 times
loudboy10 wrote: Fri Jan 16, 2026 11:38 pm Are the ZombieInverter PCB dimensions available? I'll be ordering one soon and would like to print my own enclosure. Of course I can take measurements once I have the board in hand, but I'd like to use official specs if possible.
Ah... you are obviously inexperienced with car conversions. Connector is there for you to gain experience and use additional fuinctions later when applicable. Together with casing it was designed to withstand terrible vibration and moisture changes that the car enviroment is.
I warmly suggest you use the board with connector and casing that was designed for it.
You have been warned.
https://www.aliexpress.com/item/1005005 ... in_prod%3A
EDIT: if you can get a plastic 56pin case option for this would be really optimal to go with 56pin connector that can be get on Aliexpress as well...
https://www.aliexpress.com/item/1000033 ... in_prod%3A
loudboy10
Post by loudboy10 »
modellfan wrote: Sat Jan 17, 2026 1:51 pm Just buy it on aliexpress. Search for 56pin ecu
I regularly print my own enclosures; I would rather not buy something I don't need.
arber333 wrote: Sat Jan 17, 2026 4:48 pm Ah... you are obviously inexperienced with car conversions. Connector is there for you to gain experience and use additional fuinctions later when applicable. Together with casing it was designed to withstand terrible vibration and moisture changes that the car enviroment is.
Thank you for the reply, but while I have not converted a car to electric, I have plenty of other car/robot/electronics builds under my belt. 40 spare pins is excessive.
loudboy10 wrote: Sun Jan 18, 2026 2:28 am I regularly print my own enclosures; I would rather not buy something I don't need.
Why don't you develop your own stm32 board then? Minus 40pins... Software would still apply...
loudboy10
Post by loudboy10 »
