ESP data Upload bat file for windows users
Posted: Thu Feb 19, 2026 10:12 am
Hello, I'm sharing a .bat file for uploading the ESP data folder. It’s intended for those working on Windows who struggle with the Arduino IDE data upload or the .sh file available in Johannes' Git repository.
It works well for me — even better than the arduino-esp8266fs-plugin.
Copy the code above into a plain text file and save it in the parent directory of the data folder as upload.bat.
Then open the Windows Command Prompt and execute it like this: path to the bat file/upload.bat 192.168.4.1
@Johannes feel free to add it to the repo.
@echo off
setlocal enabledelayedexpansion
REM Проверка на броя аргументи
if "%~1"=="" (
echo This tool will send either one, or all data files to the web interface
echo.
echo Syntax: %~nx0 ^<hostname or IP address^> [^<path to a file^>]
exit /b 255
if not "%~3"=="" (
echo.
exit /b 255
set IP=%~1
echo Uploading to %IP%
REM Ако има втори аргумент – ползваме него, иначе ./data/*
if not "%~2"=="" (
set FILES=%~2
) else (
set FILES=.\data\*
for %%F in (%FILES%) do (
echo Sending: %%F
curl -F "data=@%%F;filename=%%~nxF" http://%IP%/edit
endlocal
