Hello, I searched a lot, but I didn't find any clear answer to my question. I´m running sine OI firmware and have ada4571 amr encoder. I'm not sure how to set correct parameters.
https://www.analog.com/media/en/technic ... DA4571.pdf
It have two sine waves per 360° revolution. Output amplitude is 0,875V - 2,545V, so mid point is 1,71V and sincos offset is set to 2122. I think that is ok.
Encoder set to sincos, but what about resolver pole pairs? If here are two sinewaves per revolution, then correct setting is 2?
Thank you.
Parameter settings for ADA4571 amr encoder
- Been thanked: 1918 times
Re: Parameter settings for ADA4571 amr encoder
yes
