Canbus extension board
zippy500
Has thanked: 76 times
Post by zippy500 »
For those of us who are pre canbus era, I have ruined my leaf adapater board tring to solder extra wires directly to it .
Just a idea would this tiny board work with the V3 board connected to the can bus,
could wire directly to the board, inputs and outputs
It was orignal made for motor sport, fits in the middle of the steering wheel so you connect pots, switches, LEDs.
https://rrrshop.co.uk/ecumaster-steerin ... 1116-p.asp
quick overview:
CAN BUS 2.0B
500 or 1000kbps, user selectable
different CAN ID and CAN frame structures can be selected,
only 25x25mm in size,
8 switch inputs (switched to ground)
8 analog inputs / rotary switch inputs, 0-5V, 10bits
4 low side outputs (0.5A, resistive and inductive loads)
6-22V power supply
+5V output for powering rotary switches, sensors and potentiometers
do you think this could work ??
celeron55
Has thanked: 38 times
Been thanked: 136 times
Re: Canbus extension board
Post by celeron55 »
I'm not familiar with those Ecumaster products and they show no screenshots of their configuration software.
It will probably work fine, especially as even if you can't configure that board, the huebner software can be configured to accept whatever that board is sending by default.
Has thanked: 382 times
Been thanked: 1575 times
Nice find indeed. I wonder if there is some Chinese $1 version of this ;)
zippy500
Post by zippy500 »
I was just looking at your wiki, im not familiar with can bus, On Johu wiki says the format is Little-endian the ecomaster says it is using Big endian will this be a cross talk issue
Endianess becomes a problem for more than 8 bit values. So shouldn't be an issue for digital stuff and with analog inputs you might be able to limit resolution to 8 bits.
joromy
Post by joromy »
This is also a good alternative.
http://skpang.co.uk/catalog/teensy-canb ... -1507.html
Has lots of free/open software.
Not open source hardware, but you get schematics.
Have used this myself, it just works.
Don't have all pins broken out, that's why I made my own board.
