Page 1 of 1
Control of the two inverters at the same time
Posted: Wed Apr 29, 2020 5:52 pm
by yaroslav
Hi! Сan connect two control units via the can bus to control both units synchronously, connect the accelerator pedal to one control unit, and transmit the position of the gas pedal to the second control unit via the can bus ?
Re: Control of the two inverters at the same time
Posted: Wed Apr 29, 2020 7:22 pm
by johu
Absolutely.
Map "pot" to can bus on inverter 1, e.g.
can tx pot 1 0 16 1
And on inverter 2 (set potmode to CAN)
can rx pot 1 0 16 32
Configure the same throttle ranges etc. Done
Posted: Thu Apr 30, 2020 7:18 am
by yaroslav
Thank you, everything worked
Posted: Fri May 01, 2020 1:50 am
by MattsAwesomeStuff
yaroslav wrote: ↑Thu Apr 30, 2020 7:18 am
You sure?
Because I don't see any pictures of video...
"I slept with Scarlett Johansson"
... not very convincing, is it?
Posted: Sun Sep 13, 2020 6:44 am
by Bowser330
Any update on controlling two motors, would love to hear about the build!
Posted: Sun Sep 13, 2020 8:10 am
by yaroslav
The Assembly will be a little later, the engines will be connected through a coupling.
