Page 1 of 1
Broken current sensor
Posted: Sat Jul 11, 2020 11:29 pm
by Stinny78
Managed to break the current sensor while swapping the board on my small rear drive unit.
Can anyone help me with a replacement current sensor?
Thanks in advance.
Re: Broken current sensor
Posted: Sun Jul 12, 2020 8:08 am
by johu
I remember Damien found the part number. It is actually just the hall sensor you need to swap, the magnetic core can stay in. I guess you can start to remove the sensor from the core and wait for Damien to post the part number. I can't find it right now even though it should be on the forum somewhere.
Re: Broken current sensor  [SOLVED]
Posted: Sun Jul 12, 2020 8:15 am
by Jack Bauer
viewtopic.php?f=10&t=77&start=20#p2266
Please post support questions in the relevant support thread.
Posted: Sun Jul 12, 2020 12:07 pm
by johu
Thanks Herr Bauer ;)
Jack Bauer wrote: Sat Aug 03, 2019 8:00 am The current sensor used on the small drive unit is the Melexis MLX91209.
https://www.mouser.ie/ProductDetail/Mel ... 4jl%2Fc%3D
The 7.3mV/mT version.
I closed the support thread because, as we just witnessed, its hard to find info there even for the forum founder ;)
Posted: Fri Jul 24, 2020 5:18 pm
by ViktorT
The same thing happened tome a few hours ago. Great to see this information :)
Mr Stinny, did you succeed to change the sensor?
There seems to be two hall sensors, are both needed anyway?
Posted: Sat Jul 25, 2020 10:34 am
by ViktorT
viewtopic.php?f=10&t=77&start=40#p3132
On this page you can see how to insert the hall sensor
