BMW phev battery thermal management
Posted: Sun Jul 12, 2020 7:08 pm
I have been thinking about how to thermally manage the BMW batteries (or similar) and was wondering on the general consensus within the forum, as there seems to be quite a variation on what extent to go to. I am currently just trying to sort out a plan for when I'm ready.
My plan is probably going to be an electric mx5 so weight is going to be critical..and as always it's going to be done on a shoe string
At one end of the spectrum is OEM level such as zero ev's (or similar) cooling plates and all of the complexity of actively cooling and heating the batteries
Or the other end Damien's 10mm heatsink and just monitor what temp the batteries are. (I know this is not the most extreme but it's as far as I would go wilst keeping it safe)
My thoughts are sort of a middle ground ... And keep it as simple as I can .... Controling with an Arduino and relays etc
1. Use a sheet a aluminium as a heatsink to dissipate the heat to the battery box (also aluminium)
2. Bolting a some ntc heaters to the heatsink that would only heat when the batteries are cold (less than 5 Deg) and when plugged in.
3. Possibly bolting a couple of 240x40mm (AliExpress) water block to the heatsink and just flow the exhaust water from the Inverter and motor when the batteries are below let say 15 deg.
4. Set alarm and shutdown temps (34/50).
What's everyones thoughts?
