Outlander front motor teardown
Posted: Sat Aug 01, 2020 5:55 pm
by Bigpie
Just had been tearing down the front motor of the pair attached to the gearbox from an outlander, main aim was to see if I could retrieve one of the thermistors. Plan B might be to lay the stator in a bath of oil and heat it and take readings instead.
Is there anyway to determine pole count from the photos?
Re: Outlander front motor teardown
Posted: Wed Aug 05, 2020 3:58 am
by Eflyers
Just to clarify: Is this front motor a synchronous(with PMs on or in the rotor) motor or is it an asynchronous(induction) motor with no magnets on or in the rotor?
Posted: Wed Aug 05, 2020 7:24 am
by Bigpie
https://openinverter.org/wiki/Mitsubish ... _Transaxle I've added to the wiki with additional info.
The rotor has magnets in there. I've not yet reassembled if there's anything you want to know or further photos.
Posted: Thu Aug 06, 2020 11:55 pm
by slow67
You should be able to figure out how many poles it is with some metal filings.
