Energy Stored in Inverter Capacitors
Posted: Tue Aug 04, 2020 4:42 pm
Hello All,
This may be an obvious question to the Electrically Initiated..
But I’m a humble petrolhead trying to understand the basics
But I’ve looked through the forum and can’t see an answer to my question so please can someone offer some wisdom?
My question is: Inverters and EV sub systems such as AC chargers and DC-DC converters have link and filter capacitors that can handle a fair amount of energy.
When you want to use an EV and connect the High Voltage DC traction pack to the Inverter, it’s safe practice to use a pre-charge circuit (relay and resistor) to limit the current to the capacitors in the inverter so that they can build up charge slowly and not cause large in rush currents across the Main Contactors (which can weld them).
What happens to the energy stored in the capacitors when the contactors are opened again suddenly? For example if the car is in an accident, the Contactors open isolating the HV DC pack and make it safe. However there could still be dangerous to touch levels of energy stored in the capacitors for emergency responders attending a Traffic Accident?
