Reverse-engineering Chevy Bolt BMS/ Charger/ DC-DC 14v
Posted: Thu Mar 28, 2019 10:41 am
by TheLifeHacker
I am building an EV with the above items and using them in conjunction with Chevy Bolt battery pack and Tesla drivetrain. Does anyone have a contact that can make the Bolt components work in this build?
Re: Reverse-engineering Chevy Bolt BMS/ Charger/ DC-DC 14v
Posted: Thu Apr 04, 2019 10:17 pm
by Kevin Sharpe
TheLifeHacker wrote: āThu Mar 28, 2019 10:41 amDoes anyone have a contact that can make the Bolt components work in this build?
What's your budget for this development?
Posted: Sun May 12, 2019 7:04 am
See if you can use CAN MSG from Volt components?
https://leafdriveblog.wordpress.com/201 ... dc-or-apu/
https://leafdriveblog.wordpress.com/201 ... a-charger/
https://leafdriveblog.wordpress.com/201 ... ic-heater/
https://leafdriveblog.wordpress.com/201 ... -and-fans/
Posted: Mon Feb 24, 2020 11:04 pm
by Paerel
Hi, Iām doing EV convention based on Tesla big drive unit and Chevy Bolt batteries. I have in my shop complete car Chevy bolt (damaged a little but I can make it run) if you need any support - let me know
I can scan and record can-bus signals or what ever you may need
Also I have Chevy bolt wiring diagram
Posted: Thu Feb 27, 2020 2:03 pm
by Boxster EV
Speak to tom91 (Tom De bree). He can provide you with a virtually out of the box, cost effective solution for the Chevy kit.
Posted: Thu Feb 27, 2020 3:28 pm
by slow67
Boxster EV wrote: āThu Feb 27, 2020 2:03 pm
He has done the Chevy Volt, not Bolt.
Although it is worth checking if they reused the same CAN commands.
Posted: Thu Feb 27, 2020 6:28 pm
I believe with the Bolt and Volt gen 2 they went a step back, alot of the controls are pwm/analogue signals so you require a working vehicle to reverse engineer.
If anyone is based in the UK I could potential help out, at some form of compensation.
