BMW i3 Inverter
(Redirected from I3 inverter)
BMW I3 inverter
BMW I3 inverter
There are 2 variants of the i3, the standard i3 with motor power rated at 125kW and the i3s rated at 135kW.
There are 2 subvariants, as REX versions have an additional 25kw inverter and onboard generator.
Openinverter Drop-in Board
Openinverter i3 drop-in board
The drop-in board houses the openinverter, generates 32V for the gate driver board, communicates via SPI with the gate driver board to obtain voltage and temperature readouts, and provides outputs to operate contactors. See bottom of the page for list of modifications required for these boards to work. Pinouts for the three connectors on this board below.
Pinout for Ampseal Plug
Pin No Assigniment Description
1 12V
2 BRAKE_IN
3 PRECHARGE_OUT
4 CANL
5 CANH
6 DCSW_OUT
7 FORWARD_IN
8 REVERSE_IN
9 5V (OUT)
10 RESOLVER_S2/ENCODER_A Sin Hi
11 GND
12 RESOLVER_S1 Sin Lo
13 THROTTLE1
14 THROTTLE2
15 RESOLVER_R1 Ex Hi
16 RESOLVER_S3/ENCODER_B Cos Hi
17 MTEMP+
18 MTEMP-
19 RESOLVER_S4 Cos Lo
20 EMCYSTOP_IN
21 GND
22 RESOLVER_R2 Ex Lo
23 START_IN
Pinout for Gate Driver Board
Pin No I/O Description Notes Pin No I/O Description Notes
1 21 GND Switching Mosfets ?
2 I 32V in 22 GND Switching Mosfets ?
3 I 32V in 23
4 I IGBT A HI 24
5 I IGBT A LOW 25
6 I CS (ADC) 26 GND IGBT Driver ground
7 I SDI 27 GND IGBT Driver ground
8 I SDO 28 GND IGBT Driver ground
9 I SCK 29 GND IGBT Driver ground
10 I IGBT B HI 30 GND IGBT Driver ground
11 I IGBT B LOW 31 GND IGBT Driver ground
12 I IGBT C HI 32 GND IGBT Driver ground
13 I IGBT C LOW 33 5V IGBT Driver Power
14 34 5V IGBT Driver Power
15 35 I IGBT PSU on (5V or 12V)
16 O IGBT DRIVER UVW Upper Ready 36 O IGBT Driver Fault
17 O IGBT DRIVER UVW Lower Ready 37 I 5V LEM Current sensor Power
18 O Current Sense C Signal 38 GND Current sensor Ground
19 O Current Sense B Signal 39 GND Current sensor Ground
20 O Current Sense A Signal 40 GND Current sensor Ground
Note: Pin 35 is connected to a mosfet gate on the gate driver board and has been tested with both 5V and 12V.
Motor Resolver & Temperature Sensors
12-pin PCB header to connect to the motor sensors is an ERNI MiniBridge, part number 294920
Wire colours to pin allocation below determined by schematic and multimeter trace, with resolver coils and temperature sensors checked for resistance. Confirmed with motor bench test.
ERNI Minibridge Connector. Dots indicate pin 1.
Pinout for ERNI Microbridge
Pin No Colour Description Notes
1 Brown Sin Hi Twisted pair. 22.4 - 33.6 Ω.
2 Blue Sin Lo
3 Yellow Ex Hi Twisted pair. 22.4 - 33.6 Ω
4 Green Ex Lo
5 Red Cos Hi Twisted pair. 13.6 - 20.4 Ω
6 White Cos Lo
7 Blue Temperature
Sensor
From BMW Service Technical Training Manual - I01 High-voltage Components:
There are two stator coil temperature sensors.
The rotor temperature is determined using readings from the stator temperature sensors.
8 Grey
9 Red Temperature
Sensor
10 Grey
11 - Unused These wires terminate in one of the six pin connectors in the motor housing. There is nothing connected to them.
12 - Unused
Mod 1. Close SJ3
Modifications required to drop-in boards
Five modifications are required for the drop-in boards to work, plus an additional one if using CAN communication.
Mod 1. Close SJ3 on the openinverter board with solder
This enables SPI communications by assigned Pin 4 on JP2 as the MOSI line. Additional explanation here.
Mod 2. Motor Resolver & Temperature Sensor Adaptor Boards
Mod 2. - Ampseal adapter board
Mod 2. - ERNI Microbridge adapter board
A pair of adaptor boards (see also images to right) are available and shipped with the current drop-in boards. These enable the ERNI Microbridge connector from the resolver and motor temperature sensors to be connected to the required pins on the Ampseal connector. Design files for these boards will be posted on github at some point - if you need a copy in the meantime contact user 'CJW' or post on the i3 controller hacking thread.
Mod 3. Code Update for Gate Driver Board - SPI Commication
The BMW i3 gate driver board communicates the DC bus voltage (ie traction battery voltage) and IGBT heatsink temperatures to the Openinverter via SPI.
On the Openinverter mini mainboard, pin 17 on JP2 is normally used as an 'Error Output'. When used with the BMW i3, this pin must instead be used for the SPI Clock signal.
To avoid the clock signal being pulled high or low by the pin acting as an Error Output, find this section of code in vehiclecontrol.cpp:
//Brake pin is used as SPI_MISO
DigIo::brk_out.Configure(GPIOC, GPIO5, PinMode::INPUT_FLT);
and insert these lines of code below it, to disable the Error Output:
//Disable err_out so it doesn't pull the clock signal up or down
DigIo::err_out.Configure(GPIOC, GPIO10, PinMode::INPUT_FLT);
Mod 5. - Gate driver PSU power pin
Mod 4. Check solder connections on the drop-in board
The 40 pin surface mount Harwin connector to the gate driver board may have dry joints or shorts.
Mod 5. Gate driver PSU power pin
Pin 35 of the Harwin connector to the gate driver board is not connected to anything. Testing indicates this must be powered for the gate driver to work, at least on some boards. The motor has been run successfully with 5V to this pin via a 100 Ohm resistor from the adjacent pin 34, which receives power from the openinverter's 5V supply. Some earlier notes in the i3 hacking thread suggest it may also have been tested with 12V.
Mod 6. CAN slew rate pin
This pin is floating but needs to be tied to ground with a resistor if CAN communication is used. Can be any value from like 0R to 20k, the value controls the slew rate.
Openinverter Parameters
This initial set of parameters have been used for successfull bench testing a motor with a pair of lead acid car batteries. Will update and eventually post a full set of parameters here once the motor is properly set up and has been tested with a high voltage battery.
Future Development
List of tasks to be completed to enable full use of these motors:
  1. Motor temperature sensor to be mapped and added to code
  2. Design files for adaptor boards posted to github
