VW Hybrid Battery Packs
Specification Overview
Disassembly
Useful/Tools used:
- Electric Screwdriver
- Insulation Tape & Duct Tape
- Voltmeter
- Insulated shoes
- Work in the dry obviously
BMS
The BMS slaves on the modules can be re-used using SimpBMS running on a Teensy.
