VW Hybrid Battery Packs
Revision as of 20:07, 13 February 2021 by Bigpie (talk | contribs) (→‎Golf GTE)
Specification Overview
Passat GTE
Golf GTE
Disassembly
Useful/Tools used:
  2. Electric Screwdriver
  7. Voltmeter
  8. Insulated shoes
  11. Work in the dry obviously
Golf GTE
Main terminal
Main terminal
BMS
Battery Modules
Passat GTE
Module Weight
BMS Board
Golf GTE
Module Label
Module Label
Lower Mounting bracket
Higher mounting bracket
BMS slave Board
BMS slave Board
Cooling
Original Pipework Connector
Contactors/Pre-Charge
Passat GTE
The Control box contains
  • PEC 300A 450VDC fuse
  • 1 x Contactor Control Board
Contactor Box
HV Contactor
Pre Charge Relay
pre charge resistor
Fuse
Shunt
Control Board
TE 1-963539-1
The pinout is as follows:
1 Green
2 Green
3
4 Black/Grey
5
6 Brown
7
8 GND Brown/Red
9 GND Brown/Red
10 +12V Red
11
12
13
14 CANH Orange/Blue 120 OHM
15 CANL Orange/Brown 120 OHM
16 +12V Yellow
17
18 GND Brown/Red
Can output ...
CAN ID Function Notes
000000BB
18FED007
0000015B
18FED008
18FED009
18FED00A
18FED003
18FED004
1A55545F
16A95419
18FED006
18FED002
18FED005
Golf GTE
The control box contains a
Golf GTE Fuse
Golf GTE Fuse
Main Control Box
Main Control Box
Pre-charge relay
Pre-charge relay
Contactor
Contactor
1 Connects to battery case Black Ring terminal on the end, maybe for isolation test?
2 Gnd Black
3 N/C
5 CAN L Black
6-9 N/C
10 12v Red
11 12v Red Likely 12V input. When supplied, IC204 begins outputting 5V
12 White
13 N/C
14 White
15-19 N/C
21 Contactor switched gnd Black
22 Contactor switched gnd Black
23 12v for precharge relay Yellow Isolated from 12v supply
24 12v for contactor Blue Isolated from 12v supply
25 12v for contactor Red Isolated from 12v supply
26 N/C
2 x V216HC4 unknown
When the control board is powered up it emits a can message "f1 9 de ad"
Using Multiple Packs
