As these can be found affordably on eBay and from auto wreckers, they have been pursued as an open-source charger project.
External links
> CAN logs
LIM versions
| SN | IEC 61851
J1772 (AC) |
Mini cooper SE |
now |
The LIM's are available new from BMW spare parts suppliers for € 240 but there is probably some programming necessary. ???
Power Limits
The limits for pre 2017/26 (Week 26 of 2017) are 0V-500V 0A-250A, post 2017/27 (Week 27 of 2017) 0V-1000V -500A-+500A.
Connectors and Pinouts
Audi 4E0 972 713 TE 1534152-1 / 1534151-1 |
| 1B | 16 Pin Connector | Hirschmann 805-587-545 |
Audi 7M0 973 119 TE 1-967616-1 |
| X | Replacement Pins | 5-962885-1 |
| X | Rubber Seal | 1-967067-1 |
| 1B-1 | - | |
| 1B-2 | - | |
| 1B-3 | LED_M | Lighting Charge Socket? (Not necessary) |
| 1B-4 | LOCK_MOT+ | Charge Inlet Lock Motor |
| 1B-5 | LOCK_MOT- | Charge Inlet Lock Motor |
| 1B-8 | IGN | Wake up signal +12V (ignition, contact 15) |
| 1B-10 | GND | Ground |
| 1B-11 | - | |
| 1B-12 | - | |
| 1B-13 | - | |
| 1B-14 | - | Internally connected to GND |
| 1B-15 | CHARGE_E | Goes to KLE. Guessing this is charge enabled signal for the in car charger? or drive interlock signal? |
| 1B-16 | LOCK_FB | Charge Inlet Lock Feedback (1k unlocked, 11k locked?) |
| 2B-1 | CP | Pilot (Charge Inlet) |
| 2B-2 | PP | Proxy (Charge Inlet) |
| 2B-3 | Jumper | Connected to Pin 4 |
| 2B-4 | Jumper | Connected to Pin 3 |
| 2B-5 | GND | Ground (Charge Inlet) |
| 2B-6 | US CCS1 version connected to 2B-2 |
3B Pinout:
- N/A (for CHAdeMO only)
| 4B-1 | HV+_SZ+ | Contactor Control (Contactor coil resistance needs to be 15 ohms) |
| 4B-2 | HV-_SZ+ | Contactor Control |
| 4B-3 | HV+_SZ- | Contactor Control |
| 4B-4 | HV-_SZ- | Contactor Control |
| 4B-5 | U_HV_DC | Charge Inlet DC Voltage (current input 3-20mA?) |
| 4B-6 | LED_RT | Charge Status Light |
| 4B-7 | LED_GN | Charge Status Light |
| 4B-8 | LED_BL | Charge Status Light |
| 4B-9 | LED_GND | Charge Status Light Ground |
| 4B-10 | COV_MOT- | Charge Inlet Cover Motor (Not necessary) |
| 4B-11 | COV_MOT+ | Charge Inlet Cover Motor (Not necessary) |
| 4B-12 | COV_FB | Charge Inlet Cover Feedback (GND if open) |
Wiring Diagram
Required messages
this list has to be cleaned up once we know which messages are actually necessary for the LIM.
| ID | Function | interval | Notes |
| 0x112 | BMS msg. | 10ms | |
| 0x1A1 | Vehicle speed | 20ms | |
| 0x3E9 | Main LIM control | 200ms | |
| 0x431 | Battery info | 200ms | needed but does not control anything |
| 0x03C | Vehicle status | 200ms | |
| 0x2A0 | Central locking | 200ms | |
| 0x397 | OBD | 200ms | |
| 0x3F9 | Engine info | 200ms | Rex? |
| 0x3A0 | Vehicle condition | 200ms | |
| 0x330 | Range info | 200ms | |
| 0x432 | BMS SoC | 200ms | |
| 0x51A | Network management | 200ms | |
| 0x540 | Network management 2 | 200ms | |
| 0x512 | Network management edme | 200ms | |
| 0x560 | Network management kombi | 200ms | |
| 0x510 | Network management zgw | 200ms | |
| 0x328 | Counter | 1s | |
| 0x3E8 | OBD reset | 1s | |
| 0x2FA | Lim DC charge command 3. | 1s | |
| 0x12F | Wake up | 100ms | |
| 0x2FC | Charge flap control | 100ms | |
| 0x2F1 | Lim DC charge command 2. | 100ms |
LIM peripheral boards
Large fast charging contactor control board
The LIM probably measures the current draw of the pos and neg fast charging contactors which makes it a bit harder to use large Gigavac contactors with economiser.
We need a relay board with resistors to simulate the original relais coils which have ~15 ohms (@14V ~840mA).
Further investigation is needed to find out if the LIM also detects a contactor failure from the current draw profile.
Duosida inlet lock driver
The i3 has a quite expensive Phoenix CCS inlet and it would be nice to be able to use the cheaper Duosida CCS inlets.
The charge inlet lock should work with the Duosida lock as well but the feedback (1k unlocked, 11k locked) is a bit different which requires some additional resistors.
CCS charging sequence
This document actually covers Fast and Smart Charging Solutions for Full Size Urban Heavy Duty Applications but since most of the protocols used are similar it has comparable sequence diagrams with description for normal start up, normal shutdown, DC supply initiated emergency stop and EV initiated emergency stop.
Observations
