External links
> CAN logs
LIM versions
| SN | IEC 61851
J1772 (AC) |
Mini cooper SE |
now |
The LIM's are available new from BMW spare parts suppliers for € 240 but there might be some programming/codeing necessary before the unit behaves like the ones used during development of the solution.
Power Limits
The limits for pre 2017/26 (Week 26 of 2017) are 0V-500V 0A-250A, post 2017/27 (Week 27 of 2017) 0V-1000V -500A-+500A.
Connectors and Pinouts
Audi 4E0 972 713 TE 1534152-1 / 1534151-1 |
| 1B | 16 Pin Connector | Hirschmann 805-587-545 |
Audi 7M0 973 119 TE 1-967616-1 |
| X | Replacement Pins | 5-962885-1 |
| X | Rubber Seal | 1-967067-1 |
| 1B-1 | - | |
| 1B-2 | - | |
| 1B-3 | LED_M | Lighting Charge Socket? (Not necessary) |
| 1B-4 | LOCK_MOT+ | Charge Inlet Lock Motor |
| 1B-5 | LOCK_MOT- | Charge Inlet Lock Motor |
| 1B-8 | IGN | Wake up signal +12V (ignition, contact 15) |
| 1B-10 | GND | Ground |
| 1B-11 | - | |
| 1B-12 | - | |
| 1B-13 | - | |
| 1B-14 | - | Internally connected to GND |
| 1B-15 | CHARGE_E | Goes to KLE. Guessing this is charge enable or drive interlock signal? |
| 1B-16 | LOCK_FB | Charge Inlet Lock Feedback (1k unlocked, 11k locked) |
| 2B-1 | CP | Pilot (Charge Inlet) |
| 2B-2 | PP | Proxy (Charge Inlet) |
| 2B-3 | Jumper | Connected to Pin 4 |
| 2B-4 | Jumper | Connected to Pin 3 |
| 2B-5 | GND | Ground (Charge Inlet) |
| 2B-6 | US CCS1 version connected to 2B-2 |
3B Pinout:
- N/A (for CHAdeMO only)
| 4B-1 | POS_CONT+ | Positive HV Contactor Control (Contactor coil resistance needs to be ~15 ohms) |
| 4B-2 | NEG_CONT+ | Negative HV Contactor Control |
| 4B-3 | POS_CONT- | Positive HV Contactor Control |
| 4B-4 | NEG_CONT- | Negative HV Contactor Control |
| 4B-5 | U_HV_DC | Charge Inlet DC Voltage (current input 3-20mA?) |
| 4B-10 | COV_MOT- | Charge Inlet Cover Motor (Not necessary) |
| 4B-11 | COV_MOT+ | Charge Inlet Cover Motor (Not necessary) |
| 4B-12 | COV_FB | Charge Inlet Cover Feedback (connect to GND to simulate open cover) |
Connector for BMW i3 CCS plug locking actuator is BMW part number 12527549033. Pins and seals should be the same as used on the LIM module.
Wiring Diagram
Required CAN messages
| ID | Function | interval | Notes |
| 0x112 | BMS msg. | 10ms | |
| 0x1A1 | Vehicle speed | 20ms | |
| 0x3E9 | Main LIM control | 200ms | |
| 0x431 | Battery info | 200ms | needed but does not control anything |
| 0x03C | Vehicle status | 200ms | |
| 0x2A0 | Central locking | 200ms | |
| 0x397 | OBD | 200ms | |
| 0x3F9 | Engine info | 200ms | Rex? |
| 0x3A0 | Vehicle condition | 200ms | |
| 0x330 | Range info | 200ms | |
| 0x432 | BMS SoC | 200ms | |
| 0x51A | Network management | 200ms | |
| 0x540 | Network management 2 | 200ms | |
| 0x512 | Network management edme | 200ms | |
| 0x560 | Network management kombi | 200ms | |
| 0x510 | Network management zgw | 200ms | |
| 0x328 | Counter | 1s | |
| 0x3E8 | OBD reset | 1s | |
| 0x2FA | Lim DC charge command 3. | 1s | |
| 0x12F | Wake up | 100ms | |
| 0x2FC | Charge flap control | 100ms | |
| 0x2F1 | Lim DC charge command 2. | 100ms |
LIM peripherals
Large fast charge contactor control
This makes it a bit harder to use different contactors.
The easiest option is to place a 15 ohms resistor (with heat sink) in parallel to simulate the original contactor coil and a small relais to drive the large Gigavac contactor with internal PWM economizer or dual coil.
Each of the two 15 ohm resistor has to dissipate ~6W @ 13.4V, 50% PWM.
Further investigation is needed to find out if the LIM also detects a contactor failure from the current draw.
Duosida inlet lock feedback
The i3 uses a quite expensive Phoenix CCS inlet and it would be nice to be able to use the cheaper Duosida CCS inlets.
The charge inlet lock should work with the Duosida lock as well but the feedback (1k unlocked, 11k locked) is a bit different which requires some additional resistors.
RGB charge indication light
Nice push buttons with integrated RGB led are available on Aliexpress for a few dollars.
Battery voltage and current
In this setup the battery voltage and current gets measured by a Isabellenhütte IVT CAN bus sensor but those values could also be measured and shard by the BMS.
CCS inlet temperature sensors
Many CCS inlets have DC contact temperature sensors for safety. The LIM has no temperature sensor inputs but the VCU could be connected to the sensors (usually PT1000 or NTC) and reduce charging speed if the inlet gets too hot.
On board charger control
The LIM shares the PP (charging cable) and CP (charging station) AC current limits for AC charging.
If the on board charger accepts a max AC current this limits can be directly used but some chargers can only be controlled with a max DC current.
Since we don't know the actual AC current we can only estimate it with a fixed AC voltage, efficiency...
CCS charging sequence
This document actually covers Fast and Smart Charging Solutions for Full Size Urban Heavy Duty Applications but since most of the protocols used are similar it has comparable sequence diagrams with description for normal start up, normal shutdown, DC supply initiated emergency stop and EV initiated emergency stop.
Observations
LIM board components
