Nissan Leaf transmission
Revision as of 01:00, 10 October 2021 by Bratitude (talk | contribs)
the nissan leaf uses a single gear reduction box.
the input splines are the same across both the em61 and em57 motors, but the bolt pattern is different. you can not use a em61 motor with a gen2 gear box and vise versa.
both gear box's incorporate a electronic parking brake mechanism
gen 2 gearbox
a helical LSD is available for both gen 1 and 2 gearboxs from nismo japan
https://www.nismo.co.jp/products/nismo_parts/NEW_PARTS/index_2019.html#a2
gen1 with em61 motor
gear ratios
gen 2 gear box reductions gears and open diff
17:31 / 17:74
gen2 with em57 motor
gen2 leaf gear box, em57 motor and inverter
gear ratios
17:32 / 17:75
