External links
> CAN logs
LIM versions
SN | IEC 61851
J1772 (AC) |
61 35 9 380 352 | x | x | ? | BMW i3 | Nov 2015 | ||
61 35 9 494 498 | x | x | ? | BMW i3 | 2018? | x | |
61 35 9 470 199 | x | x | ? | BMW i3 | ? | ||
Mini cooper SE |
now |
The LIM's are available new from BMW spare parts suppliers for € 240 but there might be some programming/codeing necessary before the unit behaves like the ones used during development of the solution.
Power Limits
The limits for pre 2017/26 (Week 26 of 2017) are 0V-500V 0A-250A, post 2017/27 (Week 27 of 2017) 0V-1000V -500A-+500A.
Connectors and Pinouts
Audi 4E0 972 713 TE 1534152-1 / 1534151-1 |
1B | 16 Pin Connector | Hirschmann 805-587-545 |
Audi 7M0 973 119 TE 1-967616-1 |
X | Replacement Pins | 5-962885-1 |
X | Rubber Seal | 1-967067-1 |
1B-1 | - | |
1B-2 | - | |
1B-3 | LED_M | Lighting Charge Socket? (Not necessary) |
1B-4 | LOCK_MOT+ | Charge Port Lock Motor |
1B-5 | LOCK_MOT- | Charge Port Lock Motor |
1B-8 | IGN | Wake up signal +12V (ignition, contact 15) |
1B-10 | GND | Ground |
1B-11 | - | |
1B-12 | - | |
1B-13 | - | |
1B-14 | - | Internally connected to GND |
1B-15 | CHARGE_E | Goes to KLE. Guessing this is charge enable or drive interlock signal? |
1B-16 | LOCK_FB | Charge Inlet Lock Feedback (1k unlocked, 11k locked) |
2B-1 | CP | Pilot (charge port) ~620 ohms to GND is needed if no original i3 charge port is used! |
2B-2 | PP | Proxy (charge port) |
2B-3 | Jumper | Connected to Pin 4 |
2B-4 | Jumper | Connected to Pin 3 |
2B-5 | GND | Ground (charge port) |
2B-6 | US CCS1 version connected to 2B-2 |
3B Pinout:
- N/A (for CHAdeMO only)
4B-1 | POS_CONT+ | Positive HV Contactor Control (Contactor coil resistance needs to be ~15 ohms) |
4B-2 | NEG_CONT+ | Negative HV Contactor Control |
4B-3 | POS_CONT- | Positive HV Contactor Control |
4B-4 | NEG_CONT- | Negative HV Contactor Control |
4B-5 | U_HV_DC | Charge port DC Voltage (current input 3-20mA?) |
4B-6 | LED_RT | Red charge Status Light (12V RGB LED) |
4B-7 | LED_GN | Green charge Status Light (12V RGB LED) |
4B-8 | LED_BL | Blue charge Status Light (12V RGB LED) |
4B-9 | LED_GND | Charge Status Light Ground (common cathode of RGB LED) |
4B-10 | COV_MOT- | Charge Port Cover motor (Not necessary) |
4B-11 | COV_MOT+ | Charge Port Cover Motor (Not necessary) |
4B-12 | COV_FB | Charge Port Cover Feedback (connect to GND to simulate open cover) |
Connector for BMW i3 CCS plug locking actuator is BMW part number 12527549033. Pins and seals should be the same as used on the LIM module.
Wiring Diagram
CAN communication
ID | Function | sent by | interval | Notes |
0x112 | BMS msg. | VCU or BMS | 10ms | could also be sent by BMS |
0x12F | Wake up | VCU | 100ms | needed |
0x3E9 | Main LIM control | VCU | 200ms | needed |
0x2F1 | Lim DC charge command 2. | VCU | 100ms | needed |
0x2FA | Lim DC charge command 3. | VCU | 1s | needed |
0x2FC | Charge flap control | VCU | 100ms | needed (constant values work) |
0x431 | Battery info | VCU | 200ms | needed but does not control anything |
0x432 | BMS SoC | VCU or BMS | 200ms | display SoC needed |
0x03C | Vehicle status | VCU | 200ms | (constant values) needed? |
0x1A1 | Vehicle speed | VCU | 20ms | (constant values) 10ms works needed? |
0x2A0 | Central locking | VCU | 200ms | (constant values) needed? |
0x397 | OBD | VCU | 200ms | (constant values) needed? |
0x3F9 | Engine info | VCU | 200ms | (constant values) needed? |
0x3A0 | Vehicle condition | VCU | 200ms | (constant values) needed? |
0x330 | Range info | VCU | 200ms | (constant values) needed? |
0x51A | Network management | VCU | 200ms | (constant values) needed? |
0x540 | Network management 2 | VCU | 200ms | (constant values) needed? |
0x512 | Network management edme | VCU | 200ms | (constant values) needed? |
0x560 | Network management kombi | VCU | 200ms | (constant values) needed? |
0x510 | Network management zgw | VCU | 200ms | (constant values) needed? |
0x328 | Counter | VCU | 1s | needed |
0x3E8 | OBD reset | VCU | 1s | (constant values) needed? |
Messages sent by LIM | ||||
0x29E | CCS charger specs | LIM | ||
0x2EF | Min available voltage from the ccs charger. | LIM | ||
0x2B2 | Current and Votage as measured by the ccs charger | LIM | ||
0x3B4 | EVSE info CP, PP & inlet voltage | LIM | ||
0x272 | CCS contactor state and charge flap open/close status. | LIM | ||
0x337 | Inlet lock status | LIM |
LIM peripherals
Fast charge contactor
TE EVC135 RELAY, SPST-NO, DM (# 2138011-1) is used as fast charge contactor in the KLE.
Available from EV Create https://www.evcreate.nl/shop/charging/contactor-matching-lim-ccs-charging-module-from-bmw-i3/
Large contactor control
If you want to use a larger contactor with PWM economizer or dual coil use a smal relais to drive it and place a 15 ohms resistor (with heat sink) in parallel to simulate the original contactor coil.
Each of the two 15 ohm resistor has to dissipate ~6W @ 13.4V, 50% PWM.
Further investigation is needed to find out if the LIM also detects a contactor failure from the current draw.
Charge port
SEA J1772 (US) and IEC61851 (international) cover the general physical, electrical, communication protocol, and performance requirements for the electric vehicle conductive charge system and coupler.
The original i3 type 1 charge port has a 2.7K resistor between PP and PE and no resistor between CP and PE like J1772 describes.
The protocol and the electrical communication is similar for type 1 (1-phase) and type 2 (3-phase) charge ports but there is a difference in the lock mechanism which is motorised for type 2 and manual for type 1.
Charge port lock
Only important for type 2 (3-phase) charge ports.
In the i3 a quite expensive Phoenix CCS charge port is used and it would be nice to be able to use the cheaper Duosida CCS charge ports.
RGB charge indication light
Nice push buttons with integrated RGB led are available on Aliexpress for a few dollars.
Charge control
The EVSE (charging station) shares it’s limits with PWM during IEC 61851/ J1772 AC charging or PLC during DIN 70121 or ISO 15118 CCS sessions but often the car can not handle the max available power of the charging station.
The actual battery voltage and battery current is needed by the LIM to check the respond of the charging station. In this setup the battery voltage and current gets measured by a Isabellenhütte IVT CAN bus sensor but those values could also be measured and shard on the CAN bus by the BMS. (CAN message 0x112)
Battery dependant charging current control
During (fast) charging a cell voltage and cell temperature dependant current limit is very important.
CCS inlet temperature sensors
Many CCS charge ports have DC and AC contact temperature sensors to avoid overheating if the contact resistance is high for some reason. The LIM has no temperature sensor inputs but the VCU / charge controller could be connected to the sensors (usually PT1000 or NTC) and reduce charging speed if the inlet gets too hot.
On board charger control
The LIM shares measured PP (charging cable) and CP (charging station) AC current limits in the CAN message 0x3B4 EVSE info.
If the on board charger accepts a AC current limit this value can be directly used but some chargers can only be controlled with DC current commands.
Since we don't know the actual AC current we can only estimate it with a fixed AC voltage and charger efficiency.
CCS charging sequence
This document actually covers Fast and Smart Charging Solutions for Full Size Urban Heavy Duty Applications but since most of the protocols used are similar it has comparable sequence diagrams with description for normal start up, normal shutdown, DC supply initiated emergency stop and EV initiated emergency stop.
LIM logs
Observations
LIM board components
Chip | Description | Function | Datasheet |
Renesas V850E2/FG4 | 32-bit Single-Chip Microcontroller | main MCU | https://www.renesas.com/us/en/document/dst/data-sheet-v850e2fg4 |
Qualcomm QCA7000 | HomePlug® Green PHY, single chip solution | PLC Green PHY | https://openinverter.org/forum/download/file.php?id=9611 |
Infineon TLE 7263E | Integrated HS-CAN, LIN, LDO and HS Switch, System Basis Chip | CAN, 2xLDO, wake-up | https://docs.rs-online.com/db13/0900766b814d680b.pdf |
TI SN74LVC2T45-Q1 | Dual-Bit Dual Supply Transceiver with Configurable Voltage Translation | https://www.ti.com/lit/gpn/sn74lvc2t45-q1 | |
NXP 74LVC1T45 | Dual supply translating transceiver | https://datasheetspdf.com/pdf-file/648034/NXP/74LVC1T45/1 | |
STM L9951XP | Actuator driver | inlet lock motor | https://www.st.com/resource/en/datasheet/l9951.pdf |
STM TS321 | Low-Power Single Operational Amplifier | https://www.ti.com/lit/gpn/ts321 | |
TI LM2902 | Quadruple general-purpose operational amplifier | https://www.ti.com/lit/gpn/lm2902 | |
STM VNQ5E250AJ-E | Quad channel high-side driver with analog current sense | LEDs?, contactors? | https://www.st.com/resource/en/datasheet/vnq5e250aj-e.pdf |
