Nissan Leaf BMS
Revision as of 07:33, 26 October 2019 by Johu (talk | contribs)
Here we collect information about Nissans BMS.
Connectors
Credit goes to Wolftronix for figuring this out.
You will also find it on the diyelectriccar forum, you will need to sign up for downloading
P4 24 pin P3 32 pin P6 16 Pin P5 40 Pin
Pin Cell Cell Pin Pin Cell Cell Pin Pin Cell Cell Pin Pin Cell Cell Pin
1 1 13 1 21 17 1 9 1 61 60 21
2 3 2 14 2 23 22 18 2 49 48 10 2 63 62 22
3 5 4 15 3 25 24 19 3 51 50 11 3 65 23
4 7 6 16 4 27 26 20 4 53 52 12 4 67 64 24
5 9 8 17 5 29 28 21 5 55 54 13 5 69 66 25
6 11 10 18 6 31 30 22 6 57 14 6 71 68 26
7 13 12 19 7 33 32 23 7 59 56 15 7 73 70 27
8 15 14 20 8 34 24 8 58 16 8 75 72 28
9 16 21 9 35 36 25 9 77 74 29
10 22 10 37 38 26 10 79 76 30
11 17 18 23 11 39 40 27 11 78 31
12 19 20 24 12 41 42 28 12 81 80 32
13 43 44 29 13 83 82 33
14 45 46 30 14 85 84 34
15 47 48 31 15 87 86 35
16 49 32 16 89 88 36
17 91 90 37
18 93 92 38
19 95 94 39
20 97 40
Connector part numbers
In case you need to adapt or extend the sense wires, you will need the male and female connectors and the respective pins. Here are the part numbers:
Part Number Notes
16-polig male 1473796-1
16-polig female 1318386-1
24-polig male 1473799-1
24-polig female 1318917-1
32-polig male 1473799-1
32-polig female 1318747-1
40-polig male 1376113-2 Solder part, crimp not available
40-polig female 1318389-1
Pin male 1376109-1
Pin female 1123343-1
CAN Messages
Upon powerup the unit spits out messages that contain various useful info. After a while these messages stop and you have to send 50B#00 00 00 C0 00 00 00 to get it going again.
To get the individual cell voltages, first issue 79B#02 21 02 FF FF FF FF FF. You will receive the first reply looking like this: 7BB#10 C6 61 02 0E C9 0E C0.
Now send 27 times 79B#30 01 00 FF FF FF FF FF and you get 7BB#21 0E C0 0E C2 0E C0 0E. It is one index byte and 7 data bytes. So after 28 messages you will have collected 98 words (16-bit) of data. Every other message it stretches over to the next message. The first and the last byte are unknown so we discard them. That leaves us with 97 Words. It looks much like Word 1-96 are the 96 individual cell voltages and word 97 is the total pack voltage.
