Tesla Model S/X Small Drive Unit ("SDU")
Revision as of 22:09, 25 June 2022 by Jason arnold (talk | contribs) (Added Overview, Wiring and Cooling sections. Reworked/moved existing content to better fit these categories.)
Tesla uses the Small Drive Unit (SDU) in dual-motor versions of the Model S/X. The Front SDU (FDU) is found in performance and non-performance dual-motor models, while the Rear SDU (RDSU) is only found in non-performance dual motor models.
Wiring
Low Voltage Data Connector
Housing:
Molex MX150 33472-2002 (key “B”)
Pins:
22 AWG:      Molex 33012-2003
18-20 AWG: Molex 33012-2002
14-16 AWG: Molex 33012-2001
Small Drive Unit ("SDU") Data Connector
High Voltage Power Connectors
Although the connectors are known (Rosenberger HPK series), they are not available through conventional vendors.
Drop-in control board
Tesla SDU drop-in board
Resources
Wiring connections
Purchase in openinverter shop
Setup FAQ
Application Info
Cooling
Small Front Drive Unit (FDU)
Tesla FDU cooling
Small Rear Drive Unit (SRDU)
Tesla SRDU cooling
