Audi A2 Conversion
On this page we describe the conversion of an Audi A2 1.4i petrol to electric propulsion. We will use the following components:
- Nissan Leaf 24 kWh battery pack with original BMS
- Toyota Prius Gen 2 (2004-2009) transaxle with matching inverter
- openinverter Prius Gen2 motor controller
- openinverter main board running stm32-car (VCU in ECU enclosure)
Pin mapping
We start out by mapping out useful pins of the original wire harness.
The semi-oval connectors are used throughout the engine bay. Numbering scheme: all start with part number 1J09737xx. The last two digits define pin count, arrangement and size. Examples:
- 1J0973702 - 2 pins, small
- 1J0973733 - 2x3 pins, large
- 1J0973703 - 3 pins, small.
- 1J0973723 - 3 pins, large
- 1J0973713 - 2x3 pins, small
So the last digits is the number of pins per row, second to last encodes number of rows and pin size. 0=1 row, small; 1=2 rows, small; 2=1 row large, 3=2 rows, large. The matching counterparts have an 8 in place of 7, e.g. 1J09738xx. When the part number ends in a G, the casing is keyed.
ECU
The ECU has two connector slots, a smaller one with pins 82-121 and a larger one with pins 1-81. Here we map out pins useful to us
| # | orig function | our function | wire color | Engine connector |
| 1,2 | GND | as is | br | |
| 3 | permanent 12V | ro | ||
| 4 | ignition 12V | as is | ro/sw | |
| 5 | Lambda (first) heater | Reverse light loopback | gr | 733 1 |
| 28 | From generator (maybe DF) | li/bl | ||
| 33 | Throttle second pot GND | as is | gr/ge | |
| 34 | Throttle second pot (signal) | as is | br/gn | |
| 35 | Throttle first pot (signal) | as is | ge/bl | |
| 36 | Throttle first pot GND | as is | br/ro | |
| 38 | To cruise control switch * if installed | ws | ||
| 39 | Clutch pedal sensor * if installed | ro/ge | ||
| 40/41 | To Climate control display | sw/ge sw/gr | ||
| 43/54 | To instrument cluster (function unknown) | gn/sw bl/ws | ||
| 51/52 | Lambda (first) signal | CAN for Prius | bl/ws ge | 733 6/3 |
| 55/56 | Brake light switch NC/NO to +12V | ws/ro ro/sw | ||
| 57 | To cruise control switch * if installed | bl/ro | ||
| 58/60 | CAN-L CAN-H | as is | or/br or/sw | |
| 63 | Lambda (second) heater | Drive mode selection | li/ro | Cable from rear lambda |
| 64 | Charcoal filter solenoid | vacuum pump GND | bl/ge | 722G moved to 722 |
| 65 | Fuel pump relay- control | ro/br | ||
| 68/69 | Lambda (second) signal | Drive mode LEDs | bl/br ro/li | Cable from rear lambda |
| 70/71 | Lambda (first) signal | dcsw (70), prec (71) | bl sw | 733 5/4 |
| 72 | Throttle second pot 5V | as is | gr | |
| 73 | Throttle first pot 5V | as is | ge/li | |
| 75/76 | To cruise control switch * | bl/sw sw/ro | ||
| 82 | Engine speed sensor | gr/br | ||
| 85 | Intake manifold Temp/Pressure | brake vacuum | gr | 704 |
| 86 | Hall sender G40 signal | ro/sw | ||
| 87 | Engine speed sensor | gn/sw | ||
| 88/89
96/97 |
Injector 1-4 | sw/li li/sw
br/bl sw/gn |
| 83/84
91/92 117/118 |
Throttle body senror
Throttle body sensor Throttle body motor |
ro/gn gn/bl
ro/bl li/ro gn br/sw |
713
2/4, 6/1, 3/5 | |
| 93 | Coolant temp sensor | gr/ws | ||
| 98 | +5V wiring to engine bay | as is | gn/li | 704 |
| 99 | Knock sensor | ws | ||
| 100
114 |
EGR pot
EGR mot |
fake oil pressure
Fake engine oil |
br/li
li/ge |
1J0973713G
6/5 |
| 102/103 | Ignition coil bank 1/2 | gn/ro - LIN | gn/ws gn/ro | 1J0973724 |
| 106 | Knock sensor | br | ||
| 108 | GND for engine sensors | as is | gr/ro | |
| 109 | Intake manifold Temp/Pressure | bl/gn |
Many positions in the connector are vacant and we populate them with signals that we need to direct to the BMS in the back of the car. I'm using a CAT5 Ethernet cable for that. It is simply routed under the seat carpet.
| # | our function | wire color | Comment |
| 6 | CANH to BMS | bl | |
| 7 | CANL to BMS | bl/ws | |
| 8 | Permanent 12V to BMS | or | |
| 9 | Switched 12V to BMS | or/ws | |
| 10 | Charging active to BMS | gn/ws | |
| 11 | Fuel tank simulation | gn | PB7 via NPN |
| 12 | DC switch HV+ | br | Forwarded from inverter (70) |
| 13 | Precharge relay | br/ws | Forwarded from inverter (71) |
| # | Org Function | Ours | Color |
| 1/2 | GND | br br | |
| 3/5 | permanent 12V | gn/ge gn/ge | |
| 4/20/21
39/40 |
First Lambda | ge ro/ge bl/ge
br/ge li/gr | |
| 6 | N290 Fuel metering valve | ro/bl | |
| 7 | Fuel pump relay control | ro/br | |
| 8/10 | CAN-H CAN-L | or/sw or/br | |
| 11/16/31
32/50 |
NOX controller | sw br/ws bl
ws/sw ge/ro | |
| 12 | Heater output switch | ge/br | |
| 13/17/30 | Air mass meter | gr/ro gr/ws li/ws | |
| 14 | Thermo-switch for coolant circulation | ro/ws | |
| 15/18/43
33/19/24 |
Throttle POT1/2 (signal/Gnd/+5) | ge/li br/ro ge/li
br/gn gr/ge gr | |
| 23/46 | Climate cotroler | sw/gr sw/ge | |
| 26/45 | Radiator fan controller | sw/ge ge/gr | |
| 35 | EGT | ro/gn | |
| 36 | Brake vaccum sensor | bl/br | |
| 37 | Sensors GND | ge/bl | |
| 48/57 | Brake light switch NO/NC | ro/sw ws/ro | |
| 42 | +5V to sensors | ge/gn | |
| 49/51/52/55 | Cruise control switch * If installed | bl/sw ws sw/ro bl/ro | |
| 53 | To airbag ECU | ws/bl | |
| 59 | Instrument cluster | gn/sw | |
| 60/80 | NOX heater | br/ws br/ws | |
| 62/64 | Current supply relay | ro gr/ro | |
| 65 | Generator DF | li/br | |
| 67 | Clutch pedal switch * if fitted | ro/ge | |
| 78 | N79 crankcase breather heater | br | |
| 81/100/101
108/109 |
Coils | ro/sw ro/bl ge/gn
ge/bl gn/ge | |
| 82/90 | G28 Engine speed sensor | gr/br gr/ro | |
| 83 | G40 Hall sender | br/bl | |
| 84 | G71 Intake manifold pressure sens | ge/ro | |
| 85/87/96 | EGR sensor + motor | li/gr li/ws ro/ws | |
| 86 | Coolant temp sensor | gr/ws | |
| 88 | N316 Intake manifold flap valve | li/ge | |
| 89 | F265 Controlled cooling thermostat | ro/br | |
| 91 | G336 Intake flap potentiometer | ge/ro | |
| 94 | G247 Fuel pressure sensor | gr | |
| 99 | +5V to sensors | li/ro | |
| 105 | N205 Inlet Camsh. timing valve | li/gn | |
| 113 | N276 Fuel pressure regulating valve | gn/bl | |
| 92/93102
107/118/121 |
Throttle body | li/ge li/gr ws
ro/gn ro/bl li | |
| 103/110/111 | Knock sensor | br br ws | |
| 106 | Sensor gnd in engine bay | gr/gn | |
| 114/115
116/117 119/120 |
Injectors 1-4 | br/ge br/ws
br/gn br/ro br/bl br/sw |
Silence errors
After disconnecting the engine and removing the ECU we have 3 errors: Low coolant level, low oil, ABS/ESP. Coolant level can be silenced by simply shorting out the corresponding sense pins. We will use the coolant reservoir of the Prius inverter. We might insert a sensor for super neat integration, but not for now.
ABS is solved just like in Touran Conversion
Same goes for oil pressure. With the sense line permanently shorted to GND we get an error at 0 rpm, with it open we get an error above 500 rpm or so. So we generate a signal that only pulls to GND above 700 rpm. I inserted the single pin into the grey 6-pin connector and bridged it to the VCU-generated signal on that same connector.
Low oil can only be cured by supplying the required signal: https://wiki.a2-freun.de/wiki/index.php/G266_-_Geber_f%C3%BCr_%C3%96lstand_und_%C3%96ltemperatur
I simulate the signal with a simple IO pin that is toggled "manually" as the time constants are rather long.
