Mitsubishi Outlander AC Compressor
Revision as of 12:10, 12 July 2022 by Bigpie (talk | contribs) (Adding details for the refrigerant connections and links to 3D scans.)
The Outlander PHEV has a CAN bus controller AC compressor. One thing to note, your old system components will likely need flushing of the old oil as it's damaging to compressor motor wiring lacquer. It can cause shorts. When getting your system refilled, it needs to contain compatible lubricating oil, POE MA68EV is listed in the manual, likely the same as other hybrids/electric cars.
Weight 6.2kg
Length 19cm
Height 20cm
Width 12cm
3D scans are here: https://grabcad.com/library/outlander-phev-ac-compressor-1
Height
Height
Length
Length
Width
Width
Refrigerant Connections
The part numbers for the Mitsubishi hoses are AMD45418, AMD46168. Unconfirmed, but thought that these fit https://www.evcreate.nl/shop/airconditioning/adapter-set-airconditioning-compressor/
Low Voltage Connection
The mating connector is Sumitomo 6189-0126 https://www.auto-click.co.uk/6189-0126?search=90980-10942 and the pinout is the same as the water heater. Connector also available cheap on aliexpress.
1 - 12v, 2 - GND, 3 - CAN H, 4 - CAN L
