VW Touran Conversion
Revision as of 15:27, 28 December 2019 by Johu (talk | contribs) (More connectors)
I will start loosely collecting infos on the VW Touran from 2004.
Throttle Pedal
The throttle pedal is analog, its signals are put onto the CAN bus by the ECU. I chose to remove the latter so I will have to look into reading the pedal directly. Here is its pin map:
Throttle pedal pin map
Pin # Color code Function
1 green/white 5V
2 yellow/green 5V
3 brown/blue GND
4 white/blue Throttle 1 0.75V-4.1V
5 green/blue GND
6 blue/black Throttle 2 0.38-2.05V
ECU connector
Touran ECU with Rev 2 main board
11 - Throttle GND (Pin 5)
12 Throttle 2 out (Pin 6)
13 Throttle 5V (Pin 1)
33 Throttle GND (Pin 3)
34 Throttle 1 out (Pin 4)
35 Throttle 5V (Pin 2)
31 Vacuum sensor GND
37 Vacuum sensor 5V
83 Vaccum sensor signal
86 Ignition On - provides enough power to run the main board
87 While the ECU was connected, bridging this signal to 12V engaged the main 12V supply of the ECU. This behaviour could not be reproduced without ECU
67 CANL
68 CANH
Power steering
As soon as you produce CAN message 0x280 it expects rpm to be above about 600rpm, otherwise there is no power steering.
CAN bus
Some Touran CAN messages
COB Id Len Function Notes
0x1A0 1 Byte 1, Bit 3: Brake pedal switch Produced by whoever
0x280 Bytes 2 and 3: RPM*4 Produced by you, Controls the rpm gauge
0x284 6 Byte 0, 1: Counter 0-F in each
Byte 2-5: 0
20ms
0x288 Byte 0: sequence 0x27, 0x46, 0x8F, 0xD7
Byte 1: Temp Gauge 4/3 x temp + 48
Produced by you, Controls temp gauge. Gain 4/3, offset 48
0x380 8 Byte 0: 0
Byte 1: 0x65
Byte 2: Throttle 0-0xFE
Byte 3-6: 0
Byte 7: Throttle delayed or filtered maybe + idle throttle as it's never 0
It's not actually that constant but apparently sufficient for DSC
0x38A Byte 1, Bit 0: Cruise on/off, Bit 1: Disable button, Bit 2: Set-, Bit 3: Set+
0x480 8 Byte 0: sequence 0x10, 0x68, 0x94, 0xC0
Byte 1, Bit 2: EPC, Bit 3: engine
Bytes 3,4: Consumption signal - incremental. Increasing by 28 results in 10l/h
Byte 5: 0
Byte 6, Bit 2: Cruise light, Bit 4: Message "Motorstörung Werkstatt!"
Byte 7: XOR of Bytes 0-6
Controls various indicator lights and fuel consumption display
0x488 8 Byte 0: Counter 0-F << 4 + 8
Byte 1-4: 21, 21, 7E, A6
Byte 5-6: 0
Byte 7: Counter 0-F << 4
0x572 Byte 0, Bit 3: Key switch in start position
0x580 8 Byte 0: 0x80 + counter 0-F
Byte 1, 2: 0
Byte 3: sequence 0x0f, 0x28, 0x7f, 0x28
Byte 4: sequence 0x1e, 0x10, 0x00, 0x10
Byte 5: sequence 0x70, 0x56, 0xf0, 0x56
Byte 6: sequence 0x0c, 0x48, 0xa7, 0x48
Byte 7: sequence 0x46, 0x90, 0x28, 0x90
100ms
CAN bus tap
I wanted to tap into the CAN bus without cutting wires. The power steering assembly is connected via a 6-pole "VW" connector that has the CAN bus on it. The respective part numbers are 1J0973713 and 3B0973813. So I looped through the 4 signals irrelevant to me and directed the CAN bus towards the inverter. The Nissan wiring loom also has a CAN bus return that I then looped back to the power steering.
Faults
On this connector we find switched 12V, GND and the oil pressure signal (top right)
After powering up the engine I got two error messages: STOP low coolant and something about an oil sensor. The first can be solved by filling the reservoir with water. The second is probably down to the missing oil level sensor. I will investigate.
Update on oil level warning: I fitted a 1k2 Ohm resistor from pin 2 to pin 3 (generates 2.5V "oil level") and the warning is gone.
Update 2: no it's not gone, it's a bit more complex. Read https://wak-tt.com/guides/ttc.pdf page 84. Maybe I can tell the dash panel to ignore the sensor.
Update 3: successfully programmed the instrument cluster to ignore the missing sensor. You need a CAN OBD adapter with matching software. Then in adaptation channel 39 change value to 0 (=sensor not present). Found here: http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1K)_Instrument_Cluster
Counter part of the shown connector has part number 3C0973837.
DSC light
A bit harder to fake was the messages for the ABS/DSC system. It seems all messages originally produced by the ECU need to be on the bus. That is Ids 0x280, 0x284, 0x288, 0x380, 0x480, 0x488, 0x580 and 0x588. So far it seems their content doesn't have to match exactly. I will update the table above.
More connectors
There is another 6-pole connector whos counterpart has part number 1J0973833. Four of its pins end up inside the ECU so it is useful for getting "miscellaneous" signals out of it. I put the oil pressure simulation and DC switch on it.
That said, there is another 10-pole connector underneath the car that has quite a few pins ending up in the ECU. It used to be connected to some kind of exhaust sensor. I'm trying to find the counterpart. I ordered 1J0973835 but it is too big. WRONG
I will use it for DC switch, fuel tank fill level simulator, hopefully CAN bus (towards LBC). I'm doing the latter because the current CAN bus layout gets disturbed by EMI.
