Mitsubishi Outlander DCDC OBC
* Length 370mm * Width 270mm * Height 150mm
DC-DC Converter
*at about 397v the dcdc appears to stop operating via the enable lines. currently untested if it continues via can.
Pinout as as follows:
- Pin 1 (Orange) NC on outlander
- Pin 2 NC on outlander
- Pin 3 (Blue) NC on outlander
- Pin 4 Sense line for DC to DC converter
- Pin 5 CHIN (Serial protocol to EV Remote wifi module)
- Pin 6 CAN H (Black)
- Pin 7 DC SW enables the DC:DC converter
- Pin 8 IGCT main power to charger
- Pin 9 Control Pilot from charging cable
- Pin 10 GND
- Pin 11 NC
- Pin 12 CHOT (Serial protocol to EV Remote wifi module)
- Pin 13 CAN L (Red)
Charge Control
CANBus Messages
0x286 byte 2 sets the DC charge current, there is a voltage setting on byte 0 and 1. The charger reads this value only once. To update it, you have to first power cycle the 12V line "Pin 8 IGCT main power to charger".
- Byte 0-1 = Voltage setpoint (Big Endian e.g. 0x0E 0x74 = 3700 = 370v) - Byte 2 = Current in amps x 10
- B0+B1 = 12V Battery voltage (h04DC=12,45V -> 0,01V/bit) - B2+B3 = 12V Supply current (H53=8,3A -> 0,1A/bit) - B4 = Temperature 1 (starts at -40degC, +1degC/bit) - B5 = Temperature 2 (starts at -40degC, +1degC/bit) - B6 = Temperature 3 (starts at -40degC, +1degC/bit) - B7 = Statusbyte (h20=standby, h21=error, h22=in operation) - - bit0(LSB) = Error - - bit1 = In Operation - - bit3 = - - bit4 = - - bit5 = Ready - - bit6 = - - bit7(MSB) =
0x389
- B0 = Battery Voltage (as seen by the charger), needs to be scaled x 2, so can represent up to 255*2V; used to monitor battery during charge - B1 = Charger supply voltage, no scaling needed - B6 = Charger Supply Current x 10
0x38A
