Volvo Power Steering Pump
Revision as of 00:57, 12 November 2022 by Crasbe (talk | contribs) (→‎Electrical Connection: Added part numbers and links.)
Part Numbers and Versions
Part Numbers[1]
Part Number Vehicle Used in Comment
30636927
31202520
36000075
36000116
36000772
36000801
36001211
36001485
36002698
36050678
8603041
8603274
The harness for the motor supply can be bought completely (Part Number: 30775461 [2]) or just the connector.
Connector A[3], Part Number: 31266849[4](not verified)
Pin Number Cable Color Function Comment
1 Red Permanent +12V for Motor Fused with 80A fuse (F2)
2 Black GND
Connector B[3], Part Number: 31346135[5](not verified)
1 Grey-Blue Ignition +12V for Control Fused with 10A fuse (F53)
2 CAN-??
3 CAN-??
CAN Bus Control
The CAN bus protocol has been reverse engineered in the rus EFI forum[6] and a LUA script example exists[7]
Mechanical Dimensions
- fittings and sizes
