Mitsubishi Outlander DCDC OBC
Revision as of 16:19, 26 November 2022 by Arber333 (talk | contribs)
* Length 370mm
* Width 270mm
* Height 150mm
DC-DC Converter
*at about 397v the dcdc appears to stop operating via the enable lines. currently untested if it continues via can. [3]
Pinout as as follows:
  • Pin 1 (Orange) NC on outlander
  • Pin 2 NC on outlander
  • Pin 3 (Blue) NC on outlander
  • Pin 4 Sense line for DC to DC converter
  • Pin 5 CHIN (Serial protocol to EV Remote wifi module)
  • Pin 6 CAN H (Black)
  • Pin 7 DC SW enables the DC:DC converter
  • Pin 8 IGCT main power to charger
  • Pin 9 Control Pilot from charging cable
  • Pin 10 GND
  • Pin 11 NC
  • Pin 12 CHOT (Serial protocol to EV Remote wifi module)
  • Pin 13 CAN L (Red)
Charge Control
CANBus Messages
Outlander Charger DBC File
0x286 byte 2 sets the DC charge current, there is a voltage setting on byte 0 and 1. The charger reads this value only once. To update it, you have to first power cycle the 12V line "Pin 8 IGCT main power to charger".
- Byte 0-1 = Voltage setpoint (Big Endian e.g. 0x0E 0x74 = 3700 = 370v)
- B5 = Temperature 2		(starts at -40degC, +1degC/bit)
- B6 = Temperature 3		(starts at -40degC, +1degC/bit)
- B7 = Statusbyte 		(h20=standby, h21=error, h22=in operation)
-  - bit0(LSB) = Error
-  - bit1	= In Operation
-  - bit3      =
-  - bit4      =
-  - bit5      = Ready
-  - bit6	=
-  - bit7(MSB) =
0x389
- B6 = Charger Supply Current x 10
0x38A
- B0 = temp x 2?
- B1 = temp x 2?
Parallel charger control:
Charger voltage control:
CAN_FRAME incoming;
 if (Can0.available() > 0) {
   Can0.read(incoming);
   if(incoming.id==0x389){
     voltage=incoming.data.bytes[0] ;
     Ctemp=incoming.data.bytes[4] ;
   if(incoming.id==0x377){
     aux1=incoming.data.bytes[0] ;
     aux2=incoming.data.bytes[1] ;
     auxvoltage=((aux1 * 256) + aux2); //recalculate two bit voltage value
void sendCANframeA() { outframe.id = 0x286; // Set our transmission address ID outframe.length = 8; // Data payload 8 bytes outframe.extended = 0; // Extended addresses - 0=11-bit 1=29bit outframe.rtr=1; //No request outframe.data.bytes[0]=0x28; outframe.data.bytes[1]=0x0F; // 0F3C=3900, 0DDE=3550, 0,1V/bit if(voltage < 193) { // if Charger senses less than 386V outframe.data.bytes[2]=0x78; // 78=120 12A, 50=80 8A, 32=50 5A, 1E=30, 3A 14=20 2A at 0,1A/bit } else if(voltage <= 194) { // if Charger senses less than or equal 388V outframe.data.bytes[2]=0x1E; } else { //any other case outframe.data.bytes[2]=0x00; } outframe.data.bytes[3]=0x37; // why 37? outframe.data.bytes[4]=0x00; outframe.data.bytes[5]=0x00; outframe.data.bytes[6]=0x0A; outframe.data.bytes[7]=0x00; if(debug) {printFrame(&outframe,1); } //If the debug variable is set, show our transmitted frame if(myVars.CANport==0) Can0.sendFrame(outframe); //Mail it else Can1.sendFrame(outframe); }
DCDC aux voltage control
if (auxvoltage < 1200) { // if aux voltage is low and DCDC is off auxState = true; // set the flag to true elapsedtime=millis(); }
DCDCauxcharge();
void DCDCauxcharge() { if ((auxState == true) && (digitalRead(Enable_pin) == LOW)) { // auxvoltage went below 12.2V digitalWrite(DCDC_active,HIGH); if (millis() - elapsedtime >= ontime) { // if aux voltage is low and for 5min digitalWrite(DCDC_active,LOW); // turn off DCDC_active relay elapsedtime=millis(); auxState = false; }} else { // if auxvoltage is OK auxState = false; // turn off DCDC_active relay } }
