I want a cheap EV Conversion
Revision as of 10:31, 8 December 2022 by Janosch (talk | contribs)
components
You will want Integrated components, that fulfill multiple functions in your build at the same time:
- cheap motor & inverter, ideally combined units (Toyota Prius Gen2 Inverter, )
- cheap batteries, this will be your biggest expense (Nissan Leaf BMS, BMW i3, repurposed hybrid batteries?)
- DC/DC converter (Mitsubishi Outlander DCDC OBC
- charger ( integrated into existing units, such as Nissan Leaf PDM, Mitsubishi Outlander charger & DCDC, Prius Inverter & charger )
legalities
If you are on a budget, make sure your locality allows what you are trying to do:
UK UK2 United Kingdom
The Netherlands
If you are looking for a performant ev conversion check the sister page.
