Mercedes-Benz Chargers
Revision as of 16:21, 13 January 2023 by Jalovick (talk | contribs) (Updated voltage on AWL-1DC-3300W-LV)
With an increasing amount of Mercedes vehicles being electrified, there is a growing range of on-board chargers that can be repurposed for projects. At this stage, they are yet to be reverse engineered, but with a variety of versions available at reasonable cost, it is worth looking into.
Chargers
Charger Models
Part Mumber Version Output Voltage Range Phases Vehicles Cooling Notes
A0009001108
A0009005909
AWL-1DC-3300W-LV 3.3 kW 170-330 Single S205
W205
Inlet on connector side Manufactured by Delta
A0009004307 AWL-1DC-3300W-HV 3.3 kW 240-440 Single W166
W222
X253
A0009006420
A0009006520
OBC Gen 3.5 7.2 kW 7.2 kW 170-450 Single (maybe Dual) W167
W205
W213 E300e 2016-2024
X253 2015-2022
Inlet on connector side Manufactured by Panasonic
Same 3 phase style AC input connector as some of the VW onboard chargers.
May also support dual phase inputs.
Data connectors are two 12 pin connectors, AC and DC connectors are yet to be identified.
Mercedes HV Charging harness cable is part number is A2055401604
