Mercedes-Benz Chargers
With an increasing amount of Mercedes vehicles being electrified, there is a growing range of on-board chargers that can be repurposed for projects. At this stage, they are yet to be reverse engineered, but with a variety of versions available at reasonable cost, it is worth looking into.
Chargers
Part Mumber | Version | Output | Voltage Range | Phases | Vehicles | Cooling | Notes |
A0009001108
A0009005909 A0009006609 |
AWL-1DC-3300W-LV | 3.3 kW | 170-330 | Single | S205
W205 W213 |
Inlet on connector side | Manufactured by Delta |
A0009004307 | AWL-1DC-3300W-HV | 3.3 kW | 240-440 | Single | W166
W222 X253 |
A4519820421 | 3.6 kW | TBC | Single | A451 Smart ForTwo 2012 | Inlet on connector side | Manufactured by Lear, used in Smart ForTwo A451
V1 of Lear OBC | |
A4519822021 | 3.6 kW | TBC | Single | A451 Smart ForTwo 2012-2013 | Inlet on connector side | Manufactured by Lear, used in Smart ForTwo A451
V2 of Lear OBC | |
A4519822321 | 5E35S0167 | 3.6 kW | TBC | Single | A451 Smart ForTwo 2013 | Inlet on connector side | Manufactured by Lear, used in Smart ForTwo A451
V3 of Lear OBC |
A4519822721 | 5E35S0197 | 3.6 kW | TBC | Single | A451 Smart ForTwo 2013-2015 | Inlet on connector side | Manufactured by Lear, used in Smart ForTwo A451
V4 of Lear OBC |
A0009006420
A0009006520 |
OBC Gen 3.5 7.2 kW | 7.2 kW | 170-450 | Single (maybe Dual) | C453 Smart ForTwo III
W167 W205 W213 E300e 2016-2024 X253 2015-2022 |
Inlet on connector side | Manufactured by Panasonic
Same 3 phase style AC input connector as some of the VW onboard chargers. May also support dual phase inputs. |
A0009009935 | 11-7.2-STAR2-HV | 11 kW (TBC) | TBC | Three (TBC) | W243
W293 W447 |
Data connectors are two 12 pin connectors.
AC connector on the 7.2 kW versions is a TE PA66-GF25-FR
The DC connector is a Hirschmann variant
Mercedes HV Charging harness cable is part number is A2055401604
