VCU Comparison
Comparison | ZombieVerter | GEVCU7 | Mini-E-VCU | iPDM56v1.1 |
Open source software | Yes | Yes | Yes | Yes |
Open source hardware | Yes | No | Yes | No |
Schematics and board layouts available | Yes | No | Yes | Yes |
Example | Example | Example | Example | Example |
Draft by celeron55
TODO:
- Add outlander vcu - Add johu's vcu - Add other VCUs that have been used by people on the openinverter forums - Fill in missing info - Add links
VCU Comparison:
- Open source software
- ipdm: Yes - zombie: Yes - GEVCU7: Yes
- Open source hardware
- ipdm: No - zombie: Yes - GEVCU7: No
- Schematics and board layouts available:
- ipdm: Yes - zombie: Yes - GEVCU7: No
- Price (roughly inc. VAT + shipping + enclosure):
- ipdm: 135€ - zombie: 350€ - gevcu7: 1500€
- In stock:
- ipdm: 2023-02 - zombie: Yes - gevcu7: Yes
- External connector pins:
- ipdm, zombie: 56
- External connector pin size range, A:
- ipdm, zombie: 5A?
- Primary use case
* ipdm: Power distribution, I/O extension * zombie: Inverter control including Toyota * GEVCU: CAN inverter control, logging
- Software platform:
- ipdm: Arduino - zombie: libopeninv - GEVCU7: Arduino
- External configuration interface:
- ipdm: USB serial, TTL serial - zombie: Wifi - gevcu7: Bluetooth, Wifi, USB serial
- Configuration format:
- ipdm: Arduino sketch - zombie: Parameter list
- Out-of-the box supported inverter brands:
- ipdm: None - zombie: OpenInverter, Nissan, Toyota, Lexus, Outlander? - gevcu7: DMOC, CODA, Brusa, PM100, C300
- MCU family:
- ipdm: AVR - zombie: STM32F1 - gevcu7: iMXRT1062
- Flash
- ipdm: 32kB - gevcu7: 16MB
- RAM:
- ipdm: 2kB - gevcu7: 1024kB
- Supply voltage range:
- ipdm: 8...16V
- Standby mode description:
- ipdm: 6mA running Arduino sketch at slow clock speed
- Buses:
- ipdm: 2x CAN - zombie: 3x CAN, 1x Toyota, 1x LIN, 1x RS232? - gevcu7: 3x CAN
- Number of inputs:
- ipdm: 14 - zombie: 10? - gecvu7: 12
- Analog inputs (including throttle and external NTC channels):
- ipdm: 5 - zombie: 6? - gevcu7: 8
- PWM inputs:
- ipdm: 2
- Additional special inputs:
- ipdm: 12V battery voltage monitoring
- Signal PWM outputs:
- ipdm: 0 - zombie: 1?
- Power PWM outputs (low / high side, A):
- ipdm: 4x L 3A - zombie: 3x L ?A
- Low-side power outputs, total A / count:
- ipdm: 20A / 10x - zombie: 5A (limited by ground pin) / 9x? - gevcu7: 16A / 8x
- High-side power outputs, total A / count
- ipdm: 15A / 10x
- Analog outputs:
- ipdm: 2x 0-500mA low side slow - zombie: 2x AC coupled, 2x digital resistors
- Power outputs readable as inputs:
- ipdm: 8
- Simultaneous customizable jumpers/resistors:
- ipdm: 32 - zombie: 0?
